Results 1 to 10 of 11
Thread: Stereo conversion, whats needed
    Regular Member Cruize's Avatar
    South East
    Default Stereo conversion, whats needed
    Hi all,
    Seen a few threads but thought i'd ask a more general question.
    I now have a 04 Vectra SRi 1.9 CDTI with a CDR2005 stereo. Not too keen on these stereo's and prefer the CD30 style which was in my old 54 2.2 SRi.
    If I wanted to convert from a CDR2005 to a CD30 what would I need?
    CD30 Stereo with married display
    Wiper stalk?
    Steering Wheel?
    Does that cover it or are there darker depths and some rewiring?
    Feb 2011
    Selby
    You might have a problem because your 04 model is probably half-canbus (given it's got a non-canbus CDR2005 radio), and the CD30 is a full-canbus radio. So there might be more to it that just swapping the radio, steering wheel etc. if the CD30 requires canbus to communicate with the steering wheel controls and other systems.
    It might work out significantly easier to fit a Sony/Kenwood/Panasonic/JVC etc which will interface happily to your half-canbus steering wheel controls with the appropriate adapter kit.
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    if you decided to get rid of your cdr2005 , gis first dibs as mines playin up.
    South East
    lol will do mate. I just dont like the look of em. Much prefer the facelift versions.
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by rich r View Post
    If it helps,
    I have fitted a CD70, Graphic display (2005 Full CAN set-up) into a non CAN Cavalier... and to do this, I used Half CAN (2003 - 53 plate) CIM and BCM modules.
    It works perfectly.
    In my opinion you will need to do the following..
    Look at BigMac's TID to GID conversion thread (to fit 32 pin display connector.)
    Then you need to rewire this per my Install CD70 How 2.
    Then you will need to convert from ISO to Quadlock connector on your head-unit. I used an SOT lead, in my case an ISO2CAR lead... £16 all in from e-bay.
    If you have climate control, then I have heard that you may need to get a Full CAN control panel for this.
    Finally, it is quite easy to convert from buttons to scrollers on the steering wheel,
    and then reprogram the CIM to tell it that you now have scrollers..
    That SHOULD be pretty much it
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i have a ncdc 2013 sat nav unit and display also 4 cd chander built in the front so nice upgrade and its for sale
    milton keynes
    Quote Originally Posted by Robsey View Post
    If it helps,
    It works perfectly.
    Also needed is a full canbus steering wheel and airbag , as the half canbus ones are a different size and shape , I completed this modifcation about 18 months ago on my old 52 plate vectra witha a cdc40.
    Jan 2010
    York
    Can't help, but can someone please tell me what the following mean please?
    CIM (I can think of something quite inappropriate for that!)
    TID
    GID
    BCM
    Engine : 1.9 CDTi
    Quote Originally Posted by PedroMV6 View Post
    TID
    GID
    BCM
    CIM: Column integrated module
    TID: Triple info display
    GID: Graphic info display
    BCM: Body control module
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by kman247 View Post
    Hmm, this is more likely pre- and post facelift where the difference lies.
    I have a full CAN (2005) pre-facelift Vectra, and the half CAN buttons fit, but the Facelift scrollers dont - so I fitted pre-facelift scrollers.
    However it does depend upon which wheel you have fitted.
    (Ours is a 4 spoke item)
  1. fitting aftermarket single din stereo to preface, whats needed?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2012, 14:54
  2. White LED conversion...help needed.
    By Ben_ in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2011, 14:02
  3. Stereo help needed
    By Jax in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2009, 09:09
  4. I want to play mp3's through car stereo 2005, whats the best way?
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2008, 13:46
  5. After market stereo help needed
    By mazz1 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2005, 00:34
