View Poll Results: does this help
Voters
1. You may not vote on this poll
  • yes
    1 100.00%
  • no
    0 0%
Thread: reversing sensors relay
    member of the smoke patrol 230bhp+
    Talking reversing sensors relay
    been asked so many time how to its better to just show you how to do the relay
    [COLOR=Red]
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Is this "if your sensors are bleeping after you install them" because of the 5 volt pulse to check the light bulb???
    I didn`t fit one to mine and they worked fine, no problems at all ...
    Here, there and every where!
    Moved this to the "car chat" section as you had put it in the "parts for sale"
    Regular Member Elite2.2DTi's Avatar
    Jul 2006
    Southampton
    Quote Originally Posted by Bainie
    Dito.
    May 2007
    Surrey
    Question Wiring Diagram
    On your diagram, you show the bulb live going to two points on the relay... are you sure this is the right way to wire it? Shouldn't one of those points go to the live of a power source not monitored by the car?
    I'm about to wire mine in you see and want to be absolutely sure this is the way to do it!
    My understanding was that drawing any current from the bulb live would cause the car to display a warning.
    Could you explain how this diagram works and confirm that it is the one you used? - Really don't want to mess up my car!!
    Quote Originally Posted by coolbloke1324 View Post
    You may find that you don’t not the relay ,,,,, but some kits will try to power up on the voltage the fault system uses
    The relay is only there to stop the feed back from the buld fault system in the car
    Fit the kit without first ,,,,,,,,and try it without but if you can hear it start to bleep as the fault system pulses you will need to put the relay in to stop the feed back to the reversing sensors
    i know what you are thinking about the relay but befor the sensor gets it power the relay need to switch and that needs about 9 volts to switch it
    hope this helps
  1. fao... those with reversing sensors
    By paul.sessions in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 22:20
  2. Reversing sensors
    By d16wal in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2008, 18:45
  3. reversing sensors
    Last Post: 6th December 2008, 15:24
  4. Reversing Sensors
    By deanos in forum Parts for sale
    Last Post: 21st October 2007, 11:01
  5. Reversing sensors.
    By alb in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2006, 15:51
