Thread: Will a remap ave a limit till engine gets warm
    Worksop
    Default Will a remap ave a limit till engine gets warm
    Ie stop boosting to full and shut off?
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    yes... you do not want to have an overboost situation..
    I had mine dialed down a bit and given more torque
    Worksop
    Quote Originally Posted by Caveman_nige View Post
    ah wondered today engine not fully warm and kept switching turbo off at 10 psi
    Jun 2009
    South Coast
    best to try avoiding using your turbo until your engine is up to temp.. its all about the oil... can't say if that was your issue though.. you will know soon enough if you have goosed it... did you fit the manual boost controller you were looking at then?
    Worksop
    not yet nige dont no were to plumb it in says in vac pipe from turbo to actuator but there is a boost sensor it goes into so no idea
    Jun 2009
    South Coast
    just reread this...your map/ecu will have limit to the boost but not sure if its dependent on the engine not being warm enough.... I would not know, i don't boot it until its around 85c
    Worksop
    lol i had to today lol and it deffo cut turbo off lol any ideas on the adjustable boost tee
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    My remapped diesel won't rev past 3000 revs when the engine is cold. No drama, just loss of momentum.
    Jun 2009
    South Coast
    just as an update..
    this morning i was 3/4 mile into my commute when i was about to be nailed by a truck (it was forced to move by other dangerous traffic) so I was forced to stomp the loud pedal. I had no such restriction and my car took off as usual and did 1.4 bar before I eased off back to normal reaffic sppeds. I only needed to do this for a short sprint fortunately as i do not like racing the engine when cold. However, as an answer to your inital question mine does not hold back when cold on its remap so I doubt yours would to. You may need to be looking at something else for to the reasons why you did not get any decent boost.
  1. Warm air from engine when its cold
    By Mikey4996 in forum Engine & Drivetrain
    Last Post: 30th November 2011, 20:23
  2. Lumpy engine at low revs, when warm., help.
    By super sleuth in forum Engine & Drivetrain
    Last Post: 28th July 2011, 20:32
  3. How long for the engine to warm up?
    Last Post: 6th January 2011, 18:03
  4. 2.2 Direct warm engine start
    By Sambor in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:12
  5. Topping up engine oil... engine warm or cold?
    By Quinten in forum Engine & Drivetrain
    Last Post: 15th May 2008, 18:39
