Thread: Condensation in headlight
    Full Member RBH's Avatar
    Jan 2008
    Central Scotland
    100 Post(s)
    Vehicle : Insignia VX Line
    Trim : SRI
    Engine : 2.0 CDTI
    Year : .....
    Default Condensation in headlight
    whats the best way to dry out the headlight?
    would i be better taking the light out altogether and doing it in the house where its warm?
    or leave it in and try and dry it out with a hairdryer?
    ijk571
    Guest
    Had this before in my old Mondeo. I took the headlights and took them indoors to change the bulbs last winter and when they went back outside the change in air temp made them condense inside. I found the best way was to take off the rear cover (to let the damp air out) and then dry them naturally or use the hair dry carefully.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    hair dryer and silicon gel packs ..
    Regular Member farley2708's Avatar
    antrim n.ireland
    i took mine out,couple of hours in front of a blow heater,got it de-misted,nice and warm,for me it was where i drilled out the cap for the HID cable to go through,so some insulating tape & a wee bit of black silicone,added a sachet of silica jel just for good measure,job seems to have been a good un,that was 4 months ago
    Jan 2008
    Central Scotland
    100 Post(s)
    Trim : SRI
    Engine : 2.0 CDTI
    Year : .....
    Quote Originally Posted by farley2708 View Post
    yep.............this has only happend since ive removed the hid kit
    Feb 2011
    Selby
    I took all the bulbs out of mine (to give the damp air plenty of ways out) then heated the headlight from the front gently with a 150W halogen lamp to get the moisture to evaporate and head out the bulb holes. Don't get it too hot or you'll melt the plastic headlight. Been mist free since.
    A pack of silica gel will help get the last of the moisture out - but remember to remove the gel when it's absorbed it, or it could just release it back when the bulbs heat up!
    The important thing is to have the rubber cover on the back of the headlight. If it's missing, split or has holes in it, then the water will just come back. Also try not to slosh screenwash all over the back of the headlight when refilling it
    Jan 2008
    Central Scotland
    100 Post(s)
    Trim : SRI
    Engine : 2.0 CDTI
    Year : .....
    so the gel packs need to come out when the jobs done then?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    As a temporary solution and I found the condensation will come back.......
    Place baking foil over the outside of the headlamp and run the engine with both dipped and main beam on. The heat generated can't escape with the foil in place but beware - don't walk away from the car and check every 2 mins or so cos the heat can melt the headlamp lens. been there, done it .
    Alternatively, use a thick bath towel instead of baking foil.
    HTH
    Regular Member bigdave1701's Avatar
    York
    I've had a misty drivers side headlamp for a couple of days. Thinking hair dryer, silica gell and sealant round the HID hole.
    Feb 2011
    Selby
    Basically dry it out however you choose, and then make sure damp air can't get back in afterwards.
    Unfortunately at the moment the air is very damp (at least here in Yorkshire), so you might still get a little bit of misting. The ideal time to do this is on a very dry, hot day in summer.
  1. Headlight condensation
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 13:25
  2. Condensation in headlight
    By shamus5178 in forum Bodywork & Interior
    Last Post: 13th June 2009, 19:23
  3. Condensation in Headlight
    By cornishpirate in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2008, 15:48
  4. condensation in headlight
    By johnny kebab in forum General Chat
    Last Post: 11th October 2007, 17:10
  5. Condensation in Headlight!
    By Robbie in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2007, 17:11
vectra c headlight condensation
vectra c water in headlights
condensation in my vectra c headlights
vectra head lamp damp
05 vectra headlamp condensationvectra c headlighthow to get rid of condensation in vauxhall astra headlightsvectra c headlight draincondensation in insignia headlighthow to dry headlight vectra cinsignia headlight condensationvectra c condensation in headlightsignum headlight watervectra c 2003 headlight coversvectra c damp headlightsmisting vectra c headlightvectra c water in headlightmondeo headlight mistingwater in vectra c headlight site:www.vectra-c.comvectra 2007 condensation inside carvectra c headlight mistinginsignia headlight mistingvauxhall vectra moisture in lightsvectra c how to get rid of damp in headlightwater in my headlight vauxhall vectra c
