Thread: starting issues 1.9CDTi 8v
    peterborough
    Default starting issues 1.9CDTi 8v
    i bought a 04 cdti 2 months ago and 2 weeks after i got it i started having starting issues. basicly it cranks over but doesn't catch the fuel. after a short while it starts. took it back to the garage numerous times and they couldn't find anything wrong. This only generally happens when the cars cold or not been used for a while.
    The garage have come back to me and said it's either the crank sensor or the flywheel but the flywheel wouldn't be covered by any warranty anyway. im stuck between a rock and a hard place cos i don't know what to do now. what the garage owner has said is if i get the part then he'll get it fitted but i don't want to start paying out for something if its not right
    Aug 2009
    Rossendale
    My previous car (1.9CDTI 120) showed the same intermittent symptoms a couple of years ago so I bought a code reader from ebay (£20) and, when the problem next occurred, plugged in the reader and determined that the crank sensor was open-circuit.
    Replacing the crank sensor is definitely the cheapest option - I recall paying around £80 fitted including the part, it takes less than an hour to fit.
    Chris
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    That was the problem on mine
    peterborough
    thanks, think i will start with that but im needing to get car serviced so think i will get glow plugs changed just incase
    Aug 2009
    Rossendale
    Do you get the spanner light showing at all? If so does it show only after cranking for a few seconds? If this is the case then the glowplugs and/or the relay wouldn't necessarily be first on my list of things to check.
    If one or more glowplugs were faulty then you'd likely get the 'spanner light' showing on the dash a few seconds after turning the key to the normal running (i.e. not the starting) position whilst waiting for the glowplugs to heat before cranking.
    Personally I would advise investing about £20 in a fault code reader that you can hook up to a laptop rather than just guessing at the problem. A garage would normally charge you £30 - £50 for a diagnostic readout so you'll save money the first time you use your own reader. It's worth it even just for peace of mind so that you have an idea of what's wrong with the car before taking it to a garage.
    Chris
    lincolnshire
    cold starting is a known probelm on the 120 , solutions can be any of the following , glow plugs , new battery, valve clearance , cranks sensor , timing belt . its tough to know which to change mind ! i did the plugs on mine and it made no difference ! i sold the car in the end , got sick of being embarressed sat there cranking it
    peterborough
    I get no spanner light but i do have a reader and if memory serves me correctly it did say something about the crank. but i was trying to get the garage to sort it that i bought the car from but they've been as much use as a chocolate fireguard! so i've given up with them. thanks for the advise
    Regular Member steve19cdti's Avatar
    Nov 2010
    s.wales.bridgend
    Hi guys ive had the problem off the starting from cold and if u leave it 5-8hr still problem ,change heater plugs ,battery ,3 injectors ,still had problem ,so I bypast he fuel filter put a clear pipe on the intake and outtakefor a day and nite drove around like this douse kick foult lite up changed it back the next day ever since it starts firt time pust **** in the fuel lines but like I said starts first time
  1. starting issues
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 26th October 2012, 07:57
  2. Starting issues
    By jonny_adams60 in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 00:02
  3. Starting issues
    By Fendy in forum Y & Z30DT Specific
    Last Post: 7th February 2012, 10:18
  4. Starting issues...
    By jones5n in forum Engine & Drivetrain
    Last Post: 9th October 2011, 18:29
  5. Starting issues !!!!!
    By Dimscreen in forum Engine & Drivetrain
    Last Post: 4th May 2011, 08:09
