Thread: Possible cause ???
    Full Member
    Nov 2009
    Warrington
    Default Possible cause ???
    Anyone any idea on this. Yesterday whilst out driving as I approached a set of traffic lights ( maybe about 4 car lengths from the lights ) I put the car into neutral and coasted to the lights ( before you all shout at me I never normally do this, I always make sure I'm in the correct gear approaching lights/junctions so can't remember why I put it in nuetral ) so anyway approuching lights foot off clutch pedal, in neutral and applying brake, just as the car comes to a stop the car starts juddering, but stops when car came to a stand still. As I didn't know what it was I tried it again at next set of lights, put it in nuetral and coasted to lights and again it juddered slightly. Any ideas ??
    Full Member
    Nov 2009
    Warrington
    Bumpady bump
    Regular Member sla002's Avatar
    hayes, middlesex
    badly warped front discs, worn bushes, play in lower front ball joints, play in inner/outer track rod ends, wheel bearings, shocks/springs.
    check shocks: bounce the front and release, the car should settle within 3 bounces if the shocks are good.
    jack it up and pull the front wheel around, have check for play.
    check spring: have a look and feel of the springs for any cracks or breaks,
    check ball joints/bushes: play when you pull top or bottom of the wheel.
    check track rods: play when you pull the wheel from the sides.
    check discs: spin the wheel to see if it spins freely.
    just a few things to have a look for, hope it helps
    Full Member
    Nov 2009
    Warrington
    Sorry I didn't explain very well. When the car began to judder the revs died a little too as if it was about to stall, then as car came to stand still the revs increased to normal. So defo engine judder. Sorry
