Thread: One sump plug or two on a VVT.
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    Default One sump plug or two on a VVT.
    Just got off the phone from my local stealers, ordering gearbox oil and a new plug---or plugs. See I was convinced there are 2, one on top for putting oil in and one underneath for draining, the guy at vx didnt think so.
    Does or has anyone changed there box oil on a 1.8vvt? Really could use someone elses experience here.
    He also couldnt tell me how much oil to put in!! arrhhhh! And these guys actually built the car?
    Thanks fellas.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    am not familiar with your gearbox but I agree that it would probably have two, most the dealer know sweet FA and need to be told.. I did not bother to change the top one though, just reused the old one.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    no drain and no filler ....simples ............draining can be done by removeing the diff pan (you will need a new gasket) but this wont get all the oil out some small amount of oil will remain in the main gearbox case and the rear case ..so to do a full drain you will need to strip it down and get a few gaskets not worth the hassle ..... to fill it you remove the upper breather and fill it via there on the side of the diff there will be a 13mm pug that is the level plug ....takes aprox 1.7L of oil ...but you will prob only get 1L out the diff pan ....good luck
    Apr 2011
    Southport
    Thanks for replies, sounds like grief undoing gaskets though, cant believe thats the only way! only flippin VX!
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by benny View Post
    f17 box has no dedicated drain or filler holes.
  1. Sump plug
    By shb1988 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 18:37
  2. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  3. Sump plug
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 8th May 2012, 20:46
  4. sump plug on my 2.2 sxi
    By smilerwas in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 22:53
  5. Sump Plug Nut
    By si_hoss in forum Engine & Drivetrain
    Last Post: 22nd February 2010, 18:32
