Thread: Kumho ecsta spt 225/45/17 tyre pressure
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Kumho ecsta spt 225/45/17 tyre pressure
    I have a set of 4 kumho ecsta spt 225/45/17 extra load tyres but im not sure what pressure they should be running at.Ive looked on the sidewall of the tyre and all it says is do not exceed 51psi.I checked the pressure the other day and all had different pressures in the ranging from 30-34psi so i couldnt even go by that really
    The tyres are not the same fitting that they fitted as stardard on my car.
    My car is a 2006 vecrta c SRI
    If it's a 2.2 then the pressures should be 32 psi all round when you have up to 3 passengers.
    Ultimately though, you should consult your handbook as different engines and passengers / loads will need different pressures. If you've not got one then it can be downloaded from Vauxhall's website.
    Aug 2011
    Basingstoke
    Trim : SRI
    sorry i forgot to mention its a 1.9DCTi.
    Yes i have the handbook but because these were not the tyres that came standard with the car i wasnt sure if they would have a different pressure
    IIRC it says 33psi in my handbook so ill stick to that
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    I usually base it on wheel diameter x 2 plus 2 psi so in your case 17 x 2 +2 =36
    and still loving it
    Aug 2011
    Basingstoke
    Trim : SRI
    Thanks mate
    Sep 2010
    According to the manual
    Front 32 psi normal load (up to 3 people)
    Rear 32 psi normal load (up to 3 people)
    Front 36 psi - fuel saving optimuim
    Rear 36 psi - fuel saving optimuim
    Front 33 psi full load
    Rear 41 psi full load
    Regular Member sla002's Avatar
    hayes, middlesex
    hi justin.
    just brought 2 kumho sport 225/45/17, for the front of mine.
    haven't had them fitted yet, so was just wondering what there like on the road, grip, noise etc.
    cheers .
    Aug 2011
    Basingstoke
    Trim : SRI
    Quote Originally Posted by sla002 View Post
    hi justin.
    cheers .
    Hi mate,just sent you a PM
    Fife
    I run Kumho KH31s 225/45/17 all round at 34 psi.
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I run the Kumho KH31 at 36 psi all around. 225/45/17 Its the 2x wheel diameter + 2 rule that I go by.
    The rears have at least 6 mm on them if not more and the fronts have worn evenly down to 4 mm. This is after 21,000 miles. (town and motorway driving)
    Im very happy with them.
    Great tyre in my mind, even in the wet.
    Will buy again for sure
    EDIT : Im running a 1.8 VVT 2006 Sri
  1. Tyre pressure
    By ed taylor in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2010, 07:23
  2. 235/35/19 Tyre Pressure
    By dwatso26 in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2010, 23:19
  3. Kumho KU31 ECSTA Sport tyres
    By PAULMAC77 in forum Handling & Braking
    Last Post: 20th November 2009, 00:41
  4. Replies: 8
    Last Post: 14th December 2008, 11:39
  5. tyre pressure
    By dancam70 in forum Suspension, Wheels & Brakes
    Last Post: 11th March 2007, 19:33
