Thread: Boost Sensor Broken?
    UK
    Default Boost Sensor Broken?
    1.9 CDI 150. I've just soaked/cleaned my boost sensor having read the sticky on this site - gosh, was it sooted up. Carefully brushing some of the muck out with a soft tooth brush it is now looking pretty clean but I noticed that down the center of the sensor from the inner body down into the plastic cage there is what looks to me a metal rod and perhaps a stiff plastic rod. The thing is - with a small screw driver I can move the metal rod sideways so that the end of it sticks outside (not too far out) of the cage. This seems a bit strange - it could be broken? Are there two 'rods' pocking down into the cage of the sensor and are they fixed? I fear mine is broken.
    UK
    OK - done a bit more reading (sorry, should have done that first). I'm guessing my two 'rods' are the metal sensor (the one that I can move) and perhaps a plastic protector of some sort. So - should the metal sensor that comes from the body down into the cage be stiff/fix? Mine has a lot of movement.
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    If the car runs ok with it like it then i wouldnt worry too much
    When i cleaned mine i didnt play around with ther internal bits as i know that they are fragile.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Can u not put a pic up fella. But to be on the safe side I'd replace it then have it fall to bits inside your engine
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    When I got a new one (2.0Dti, not CDTi) I realised that the plastic thing sticking down was a yellow component, a bit like a capacitor, and is probably the air temperature sensor.
    UK
    I've ordered a new one - I was a bit worried too about the possibility of this metal piece falling into the engine. Thanks for your help.
  1. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  2. Broken brake pad sensor
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 00:08
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
ive broken my boost sensor
ive broken my boost sensor Vectra
