Results 1 to 10 of 30
Thread: where can i get an RPM signal?
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Question where can i get an RPM signal?
    I need to find where i can attach a wire to get an RPM signal.. I have a couple of bits of kit needing this now and each one states to get it from the negative of the coil.. however i see no way of connecting a wire to the negative of one of my coils.
    Does anybody have any ideas?
    Engine : 1.9 CDTi
    Not sure on the Vectra but it used to be a green wire on the dash connection.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    according to the wiring diagram there are 2 green wires coming from the low speed CAN bus to the back of the instrument cluster, i guess its these... problem is that many places state that when they have spliced into this the instrument cluster tacho stops working, but when they desolder the wire and out it back to how it was its fine...
    It seems that many of these gadgets that require and rpm pulse signal rarely get sorted as it so tricky to get a signal that does not create other issues..
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    what about using the crankshaft sensor, will this give me a reliable rpm signal?
    Jun 2011
    Elland
    Alternator generating coil?
    This will give you a reliable signal, but you have to interpret it... as you would with pulling a signal from a crank or cam sensor.
    You may even find the alternator has a terminal for doing just this... it is how non-electronic diesels run their tachos.
    To set up an aftermarket diesel tacho (like a marine one, for example), the tacho has a setting for the number of poles in the alternator and the ratio between crank and alternator pulley sizes. This gets you somewhere close to the real RPM. You can then fine tune the tacho using a pot on the back. All the unit is is a frequency meter... you are just calibrating it to read RPM.
    So you see how using this sort of signal will give you a signal (frequency) that is proportional to the RPM, but it's how you interpret / use it...
    HTH
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    I would actually say PIN5 on the radio... (atleast that what i remember that it is.. on the prefacelift), as that also turns up the radio acording to speed..
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    Quote Originally Posted by kenp View Post
    Thats interesting Ken.... i have the CD70, i assume that it's PIN5 will be fine to try out? Will try that when i get a chance and feedback.. thanks
    Engine : 2.2 Direct
    Still think its pin 5.. but thats speed signal.. not RPM sorry...
    http://www.navi-forum.net/board/n-t20838.html
    But then there should be one on the backside of the dash... (witch i dont know)
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    i thought there might be as well.. but have not seen the back of a cluster from a vec..
    anybody got a pics of the rear of the dials/cluster
    Oct 2007
    Shropshire
    I believe it is all canbus to the back of the clocks, not sure if there is a rpm signal anymore. I think you can get a CAN BUS interface that will give you that output. What are you trying to wire in, perhaps there is an alternative. You can get gauges that plug into the diagnoistic socket....
  1. When will FM signal end ? been looking at dab radios
    By Ralphwells1967 in forum General Chat
    Last Post: 28th December 2011, 22:00
  2. mirror, signal .....
    By farmboy91 in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2011, 21:15
  3. GPS signal
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 20:07
  4. Cd70 sat nav no signal
    By gregc in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2009, 21:57
  5. No GPS signal For Sat Nav
    By steve74 in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2007, 22:08
vectra c speed pulse wire www.vectra-c.com
vectra c tachometer signal
