Thread: Diesel Knock and no compression on No.4
    Regular Member skip85's Avatar
    Wiltshire
    Vehicle : vectra c estate
    Engine : 1.9 cdti 150
    Mileage : 150000
    Default Diesel Knock and no compression on No.4
    Hi All,
    My car on the way to work all of a sudden a bad diesel knocking sound happend. parked up and got it towed in.
    Thought was injector....no. impellable on water pump broken but no compression in no4 now.
    Any Ideas??
    Am i right in thinking they are chain driven with belt for water pump?
    Help!!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Camshaft is belt driven m8.
    As for the noise, well if there is no compression on No.4 then check the injector doesn't have tar sitting round it's seat. Could be the no.4 injector seal has perished - but I'm just guessing tbh.
    Wiltshire
    Mileage : 150000
    Quote Originally Posted by Gazza4 View Post
    He has mentioned about the impellor being broken on water pump/////
    Could this have got lodged in a valve?
    Injector has been tested and all ok?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Borken impellor pump getting lodged in a valve is impossbile. And if the valve was jammed open anyway I think low compression would be the least of your worries.
    Could be knackered valve seats or compression is escaping via the injector or glowplug seats on that cylinder I think.
    Wiltshire
    Mileage : 150000
    would that cause the knock all of a sudden tho? thats why i thought injector. but all tests come back ok.
    Just want something nice and simple!!!!
  1. Increased diesel knock
    By simon987 in forum Engine & Drivetrain
    Last Post: 11th April 2013, 19:47
  2. diesel knock with reconditioned injectors fitted
    By pugs,signum in forum Engine & Drivetrain
    Last Post: 5th July 2011, 23:11
  3. DIesel Knock
    By Si-SRI in forum Engine & Drivetrain
    Last Post: 9th June 2011, 12:47
  4. Diesel pump knock
    By ads3 in forum Engine & Drivetrain
    Last Post: 8th June 2011, 18:22
  5. "diesel knock" sort of noise
    By mick.n in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 23:11
vauxhall vectra 1.9 cdti no compression
vectra c 1.9 low compression
opel vectra 1.9 cdti compression
