Thread: Cruise Control :(
    Regular Member paddyvectra's Avatar
    Jul 2011
    Carterton, but.....I walk a lonely road the only road i have ever known
    Default Cruise Control :(
    After reading many times about people having cruise control problems i thought myself lucky having not had a problem before............................big mistake!!!
    Driving back from work today on my usual lil stretch of motor way decided to hit CC to relax the foot a bit and .................................NOTHING. Nothing at all not even an attempt any idea's people?
    much love and thanks in advance
    Did you press the brake pedal at all before trying to use the CC?
    Full Member Big Sig's Avatar
    Have you done the checks with lifting the pedals?
    Jul 2011
    nope didnt press the brake tried a few things now and nothing working. what you mean lifting the pedals mate?
    The CC won't work until the brake pedal has been pressed (only needs to be done once per journey to initialise it)
    The CC disengages when either the brake or clutch pedal are depressed. If the pedal return spring is weak then the pedals won't return to their correct resting position and the clutch and/or brake pedal switches for the CC will remain activated.
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
