Thread: Can this be mended!!!!!!!!!!!!!
    Worksop
    Default Can this be mended!!!!!!!!!!!!!
    Broken feet on a irmy rear spoiler
    Regular Member Grumpybob's Avatar
    May 2011
    Sunny Grangemouth
    A good bodyshop should be able do plastic weld it.
    New Member techno's Avatar
    north east england
    try mesh and fibreglass works every time, plastic weld might snap due to down force (i could be wrong though)
    Jun 2006
    St. Helens,Merseyside
    make a small template for the bolt holes
    get some stainles bolts
    put bolt through template
    tape this to the spoiler with the bolt heads inside the spoiler
    put loads of P38 (plastic fix stuff) inside the spoiler so it is around the bolt heads(make sure the bolt heads are high enough to allow some of the P38 to encase the bolt head)
    or as above ask at local body shop
    Worksop
    think ill bin it and fit a vxr rear spioler
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Simple answer is yes, it can be repaired, there are several ways you could do it, I've seen alot worse
