Thread: loss of turbo when accelerating in high gear
    Regular Member Bigglesfliesundone's Avatar
    Jun 2011
    Darlaston
    Default loss of turbo when accelerating in high gear
    Hi,
    Hopefully someone can help as I've used the search function and my question doesnt appear to be answered (not so I would understand anyway)
    What is happening only happens in the cruise, usually motorways as I do a lot of motorway miles. I'm doing 50mph in 5th (roadworks with average speed camera) and come to gently accelerate away, engine doesnt appear to be struggling, around about 2000RPM, there is a thump, the spanner light comes on and I can only describe it as I've lost the turbo.
    Pull onto hard shoulder, switch off, switch back on, spanner light off, turbo back and car runs normally, and its really baffling me as to why this should happen..........any ideas?
    Thanks in advance
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    what engine have you got?
    Jun 2011
    Darlaston
    Doh!!!
    Apologies!!!
    2.2 DTi on a 52 plate
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by Bigglesfliesundone View Post
    Doh!!!
    Apologies!!!
    First off check all of the vacuum pipes for splits and leaks.If everything is ok on that side. Then I would say clean the egr valve, Trottle body, boost sensor and TPS. I think the throttle body and tps could be the trouble.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    and still loving it
    Jun 2011
    Darlaston
    Thanks for the suggestions, a bit more info which will hopefully confirm your diagnosis....
    This only happens in 5th between 50 and 60 mph. If I'm doing 50 and drop into 4th and pull away it doesnt replicate the fault, only in 5th between this speed range
    Is this consistent with your thoughts?
    Thanks again
    Jun 2011
    west mids
    get it on opcom as im more inclined to say its the boost vac sensor at fault as its showing the same faults mine had ,u will probably find code p1590 stored
    Regular Member Innes's Avatar
    Plymouth
    Thanks again
    It seems to happen to the DTIs. I've had this a few times. I ws bypassing it by dropping it a gear to accelerate rather than strain the engine accelerating in 5th. it only happened on inclines.
    As the guys said check all your vacuum pipes. If all okay you may need to adjust the turbo actuator rod to increase or de-crease when the turbo kicks in depending on weather you're underboosting or over boosting.
    I bet if you read the error codes it'll be:
    P0234 - Boost Pressure Control Circuit Negative Deviation
    (5A) - Not present
    It could also be a solenoid issue which solved my problem. read the 10th post down on THIS THREAD. It describes the same issue you are having.
  1. Problem accelerating up hill...high revs
    By Kerr81 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2012, 22:54
  2. Loss of power - high revs
    By ac14 in forum Engine & Drivetrain
    Last Post: 19th March 2012, 22:11
  3. Strange noise when accelerating in too high a gear
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2011, 12:25
  4. Can you Help ~ Loss of Power, High Revs
    By Diet1985 in forum Engine & Drivetrain
    Last Post: 28th June 2009, 18:23
  5. Turbo, low or high pressure
    By Big Davie in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2006, 20:54
