Results 1 to 10 of 13
Thread: z20net how to change the injectors?
    Regular Member matrix1979's Avatar
    Aug 2007
    NORFOLK
    Default z20net how to change the injectors?
    Hi people im trying to find a guide walkthrough on how to change the injectors over i have a 2.0 turbo 07 year with engine code z20net if anyone could help that would be great . also im not sure if i have the bigger injectors as fitted to newer versions ? if not ill buy the bigger ones when i change them over . cheers mark .
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    you probably have the bigger 381cc injectors already.. take the engine cover off and have a peek under the fuel rail, you will be able to see if the are a light green injectors or the smaller light blue ish coloured injectors.
    A how2 is currently being written for this..
    East Scotland Regional Organiser signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Wow that's a coincidence will try and post it up later subject to mods approval
    Aug 2007
    NORFOLK
    cheers as always
    Jan 2006
    Dalriada
    Quote Originally Posted by Caveman_nige View Post
    I was under the impression that the larger injectors in the later cars are grey in colour? I will have a look at my 06 mitsi turbo injectors tonight to see what colour they are, don't think mine will be the larger ones..
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    If you do need to change them over and aren't happy to do it, if you come down to me (you're not that far away) I'll chuck them in for you if you want. It's not a massively difficult job, bit fiddly, but ok, I changed mine when I upgraded.
    Aug 2007
    NORFOLK
    cheers ian thats a really nice gesture i may hold u to that :> any reccomendation to where to source them from at a good price?im not being cheecky can you do cam chains? on a 2.0 turbo as i think mine is slightly streched can hear it on tick over ,
    Jan 2006
    Dalriada
    I've been out changing the gearbox oil this morning as i'm off on annual leave. I checked my injectors, they are the blue ones which is interesting as mine is the TD04 turbo - mine is a may 06 car BTW
    Jun 2009
    South Coast
    Change them bud its an easy enough job. I guess the how2 has not been posted yet so will dig out a little guide I sent Phil.
    You will need a different map afterwards though, not sure if vx can help you with that for free but an aftermarket remap which will make it so much faster anyway with combination. You will love it.
    Jun 2009
    South Coast
    Here, this is what i sent out to Phil to use, hope it helps until the full How2 is ready with pics..:
    You unplug you coils from the the cylinder head and then undo the the fuel rail..
    If you have driven the car is past few hours before you do this you will need to push in the bleed valve to depressurize the fuel system.. i did this job in the morning as i wanted a cold engine to work on so had no fuel pressure to be concerned about.
    when you have unbolted the fuel rail you will find that a little coolant will escape from the banjo bolt on the left when you remove it, only a little will come out so its nothing to be concerned about. unbolt the two fuel lines the rail, have a cloth handy as little petrol will escape from these but continually.
    grab the fuel rail and give it a tug away from the block. this will pull the injectors out of the block, do not pull too far as the injectors are still connected to their loom... now unplug the wiring connectors from the injectors and then rotate the fuel rail so the injectors are pointing over the block. The injectors are held into the rail with a sliding clip, use some pliers and pull this clips away then pull out the injectors, make a note of which side the connectors point to.
    insert the new injectors into the fuel rail and put the sliding clips back on and then rotate the fuel rail back towards the head. line up the injectors in the plastic cups that sit in the head, reconnect the loom connections if you haven't already, then firmly push the fuel rail so that the injectors are nicely seated into the cups in the head.
    reconnect the two fuel lines and coolant pipe, rebolt down the rail securing bolts/nuts and the reseat the coils etc..
    That should just about do it.. be sure the rubber O rings are in good shape before using them though, you can buy spare for not much money from the dealers if you need to.. The plastic cups that they sit in will sometimes come out of the head with the old injectors, do not worry if they do, just wipe them down and check their O rings are goon and reinsert them.
  1. Z20net grey injectors.
    By richedition100 in forum Petrol Engine related
    Last Post: 18th July 2012, 20:34
  2. z20net bsr injectors
    By donaldsriT in forum Petrol Engine related
    Last Post: 22nd November 2011, 10:56
  3. Green injectors for z20net
    By tomo41 in forum Petrol Engine related
    Last Post: 3rd November 2011, 22:02
  4. Z20net Engine Oil Change
    By Marcosuk in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 18:58
z20net oil check valve
z19dth bigger injectors www.vectra-c.com
z20net bigger injectors
