Results 1 to 10 of 18
Thread: Adaptive forward lighting fault
    Regular Member Sigmacca's Avatar
    Jun 2011
    Skegness
    Default Adaptive forward lighting fault
    Hi guys
    was driving home just now and my AFL control indicator light on the dash started to rapid flash at me, so turned off ignition and restarted and all was fine untill I make a left turn and up it comes again, and again and again, manual says it's a trip to main dealers or consult a workshop
    thought I would consult with you guys first to shed any light on my lights
    regards macca
    Jun 2011
    Skegness
    Can anyone tell me if this is the motor that runs the pivot for the AFL and if so how to remove it or test it please
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    unbeleivably mate as of today i have same prob,is it the flashing light in bottom right hand side of dash binnacle? funny thing is all my lights are working perfectly so its a bit confusing
    Jun 2011
    Skegness
    same as, all lights are fine working perfect, only when I drive it and turn to the left the warning light comes on, cant even work out which headlight is giving the problem yet, taken them both out and inspected, tapped, blown and shaken them, back in, bumper back on and still the same so think one of the motors must have failed
    pain in the rear as going on holiday tomorrow
    Yes that's the up/down motor mate. I have no idea if you can buy them from the dealer seperately or not, but it'll be worth getting the code read to find out exactly what's putting the light on, or watching the lights when they do their power-on check and see if they're both moving as they should...
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Mine did the same thing earlier this year everything seemed normal only difference was the indicators didn't self cancel turned out to be the CIM, and previously it was the rear level sensor on the nearside rear wishbone that went, so many things linked in code reading time me thinks before you waste too much time and money
    Jun 2011
    Skegness
    thanks guys, everything starts up normal and works correct, it's when I drive it and make a left turn the warning light come's on
    off to the dealers it is then, bang goes my holiday money...........
    Jun 2006
    St. Helens,Merseyside
    Mine started like that
    Then the indicators
    Followed by the air bag
    Then the final fault kicked the immobilizer in and I had to be towed to the dealers
    £500 lighter but no faults
    Feb 2006
    Vehicle : Audi
    Trim : A5
    mine starts off fine then after a mile or two the light flashes and my headlights no longer swivel,very odd,my cars under warranty but not sure if the warranty would cover this fault
    Engine : 1.9 CDTi
    Any fault you should take it back if its under warranty.
    They should cover it as its not wear and tear.
  1. Adaptive Forward Lighting
    By fishphone in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2012, 21:16
  2. Adaptive?
    By zimzunga in forum Engine & Drivetrain
    Last Post: 15th September 2012, 21:25
  3. AFL - Adaptive Forward Lighting instead of standard xenons
    By Kali in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2009, 14:57
  4. Adaptive 4x4
    By MalcGSI in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2009, 15:39
  5. New intelligent lighting fault handling
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2008, 19:36
astra b1461 fault
vectra c adaptive forward lighting fault
signum Adaptive forward lighting fault
directional headlight warning signum
vauxhall astra adaptive forward lighting fault
Insignia adaptive headlight error
vauxhall vectra adaptive light warning
disable adaptive light vectra c
vauxhall insignia adaptive forward lighting fault
