Thread: revs sticking at 1000rpm
    Jul 2011
    retford
    Default revs sticking at 1000rpm
    any ideas guys, every now and then the veccy will when coasting or sat sit at 1000rpm and engine makes a revving noise, switch off and it drops to normal again, does this in gear and out of it. not all the time just sometimes
    veccy c 150 cdti btw
    cheers
    Jul 2011
    retford
    anyone?
    Jul 2011
    UK
    Year : 06
    Mine done this when alternator was going couple hours later the light came on
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Could it be the TB butterfly gettin stuck open slightly?
    try getting some carb cleaner and squirting it into the TB(throttle body)
    The only time mine revved that much on idle was when my alternator went kaput but the battery light had already been on for an hour
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Mine does it. Nothing to do with the throttle butterfly as it's always open. Seems normal as it does it on a few members motors. As long as the revs are not:
    - creeping up past the 1,000rpm as if you are gently pressing the accelerator
    - rising/staying after engine switch off.
    Then I would say it's normal.
    Jul 2011
    retford
    hmmmh, normal?? why does it do it then, never done it on any other car.
    Jul 2011
    retford
    back on this now, it went away for a couple of weeks as i had a loose connection on battery positive,,,,
    now its started again. battery connections fine...
    last time i tested the alternator and output was fine..battery output seemed ok aswell. it is now flickering lights on the dash on crank over aswell
    any ideas.battery goosed?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check alt agen mate.
    Also check batt. An check whilst cranking aswel
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
  1. sticking
    By HARRY SRI in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2012, 22:23
  2. 1000rpm engine rattle
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 21:53
  3. sticking egr?
    Last Post: 11th July 2010, 20:01
  4. revs sticking on 1.8vvt 2006
    By tyler in forum Engine & Drivetrain
    Last Post: 7th February 2008, 23:53
  5. Replies: 1
    Last Post: 21st January 2008, 23:33
car sits at 1000 rpm vectra
revs hanging vectra c
corsa c rev stuck at 1000 rpm
revs sitting on 1000 corsa c
