Results 1 to 10 of 13
Thread: Z22SE Overheating problem. Help Please
    Sep 2011
    timbuktoo
    Default Z22SE Overheating problem. Help Please
    Help Please!! Z22SE
    Changed Cylinder head gasket on a mate's car and had head pressure tested. Replaced thermostat and filled with water/antifreeze.
    App 5 - 10 mins after start up the top rad hose becomes very very hot whilst all the other hoses/radiator etc are still cold then steam starts to come out of the small pipe/hose which runs along the front of the cylinder head to the expansion bottle. The water level begins to rise and fall before eventually coming out the top of the bottle.
    If it is run with the cap on the hoses become solid due to pressure build up. The temp gauge keeps rising and the cooling fans come on but the bottom rad - thermostat housing hose is still cold
    All other hoses, heater rad, rad etc remain cold.
    I have been informed that the water pump had been replaced previously.
    Could this be a blockage/circulation problem?
    Are any bleed screws on the system?
    Any help/info would be appreciated.
    Neil
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Is the heater good thinking water pump issue or a faulty thermostat
    Sep 2011
    timbuktoo
    Hi,
    Heater remains cold, thermstat is new - actually removed it to test it! Also ran car with the thermostat out - still the same.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Would gess broken water pump if not headgasket incorrect fitted or wrong part. Impellar might of fallen of water pump
    Sep 2011
    timbuktoo
    I'll have to find out when it was changed? Is the water pump easy to access??
    Think the gasket can only go on one way!!??
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    No driven by the second chain and the impellar is down the back, u'll see a silver pipe going across the back of the engine its inside where that pipe goes in
    Head gasket left and right no but the top an bottom face don't know.
    Sep 2011
    timbuktoo
    Also, should there be a continuos flow of water to the exp bottle from the small pipe/hose?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    To be honest don't know on idle no don't think so just when its reving a little
    Sep 2011
    timbuktoo
    Quote Originally Posted by mattv6diesel View Post
    Thanks to mattv6diesel.
    Hi, The gasket can defo only go on one way due to the location of the m8 head bolts!
    The water pump was changed a matter of weeks ago by someone else during the "troubleshooting process" of this fault.
    The radiator has been flushed through with a hose as has the heater matrix.
    Could there be a problem with the Block?
    Any help/info/ideas appreciated
    Sep 2011
    timbuktoo
    Quote Originally Posted by a15nma View Post
    Had a final look at this car tonight. Removed the "small water pump drive inspection cover" (four M6 bolts) to find the chain was not attached to the drive wheel/cog on the water pump it is just lying loose inside the cover -I think this may just have something to do with the problem........
    Watch this space!!!!
  1. Z22SE 2003 Gear Problem
    By messsy in forum Engine & Drivetrain
    Last Post: 18th July 2012, 20:42
  2. vectra z22se engine problem
    By kevglady in forum Engine & Drivetrain
    Last Post: 21st September 2011, 01:39
  3. Problem with 2.2 sri (z22se)
    By mutley in forum Engine & Drivetrain
    Last Post: 7th May 2011, 16:00
  4. Acceleration problem Z22SE
    By vaidisas in forum Engine & Drivetrain
    Last Post: 6th July 2010, 16:47
  5. Problem with Overheating !!
    By Bainie in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2005, 22:42
