Thread: Brief cut in power on acceleration
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Default Brief cut in power on acceleration
    I'm having a problem when accelerating more so in the higher
    Gears ,it will start to accelerate turbo starts to kick in then power cuts for
    A second and then it starts to accelerate again ,it's a 1.9 cdti 150 I've tried to read as many posts as I can on the problem but can't seem to find the answer I'm looking for so far I've
    Renewed egr
    Renewed map
    Cleaned and re soldered joints on throttle body
    Cleaned maf
    Renewed vac pipes
    Flap rod on inlet still attached
    Renewed oil and filter
    Renewed fuel filter
    It's doing my head in because sometimes it will accelerate perfect any suggestions welcome thanks in advance
    Aug 2009
    Ascot
    Quote Originally Posted by Richard.roberts View Post
    Renewed egr
    Renewed map
    Cleaned maf
    Renewed vac pipes
    Renewed fuel filter
    Not the exact same problem, but what about 3rd injector wiring? And u tried the fuel filter
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    soz forgot to mention ive already done the 3rd injector mod mate ,cheers for the quick reply
    funny thing is though more often than not when first started
    from cold for the first couple of miles it seems to accelerate like it
    should
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Are you describing a short sharp snap on/off or a smooth on/off on/off on/ff about 3 times during acceleration like a progressive pulse pulling!, If its the latter i believe that's normal with a good cdti 150, Not everyone gets this but i think its a mix of the multi point multi stage injectors & variable vane turbo, It only seems to happen in higher gears when power is demanded & not in lower gears with higher revs.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    it is like you describe a short sharp off/on and only seems to happen
    once, going through each gear ,ive read a few threads on overboosting
    where the ecu cuts fuel when it starts to overboost thats what it kinda feels like (just to describe) but i dont think its overboosting
    ive got no check engine light and no faults stored and it drives lovely exept for this blip in power
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Do you know what rpm it happens at & is it usually around the same rpm in all gears that are affected, is it more noticable in 2 & 3rd.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    it happens just over 2000 revs(about) and yeh seems to happen at same revs its alot more noticable in 4th and 5th ,i can re-create it nearly every time changing up from 3rd to 4th but also pulling from low down(revs) in a higher gear if you know what i mean.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    How long has your replacement egr been on, Its the same symptom as sticking egr, Is it from vx, have you had any software updates since its been fitted.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    i unplugged the egr a while back after reading a few threads on it just to try it and it did increase throttle response so i left it unplugged dont know if that is related to the blip in power but im not convinced it is
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    i read a thread earlier ,the guy described the exact same problem as mine ,blip in power on acceleration he said it turned out to be the maf
    he said he had it cleaned and reset, i dont know what he means by reset
    would it be remove negative terminal on battery for a while to reset ecu or
    a tech2 reset or is there another reset method?
  1. Power loss, judder under acceleration
    By JonnyB_UK in forum Y & Z30DT Specific
    Last Post: 14th August 2012, 12:06
  2. HELP! No Acceleration
    By Aidi in forum Engine & Drivetrain
    Last Post: 4th April 2011, 14:52
  3. Sluggish acceleration & power steering failure
    By grogsy in forum Engine & Drivetrain
    Last Post: 5th August 2009, 17:30
  4. Dip in acceleration...
    By Stevie-B in forum Engine & Drivetrain
    Last Post: 23rd April 2008, 15:03
  5. 3.2 Acceleration
    By jamesr in forum Engine & Drivetrain
    Last Post: 16th March 2008, 13:23
