Thread: Radio/Clock/Temperature display bulb type?
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Default Radio/Clock/Temperature display bulb type?
    There have been a few people ask how to replace the bulbs behind the radio/clock/temperature display, but i haven't been able to find out what type of bulb it is, there's just a 12v 2W & Osram on the bottom of it.
    Anyone got any idea what code it is, as all i could find in Halfords & on ebay were 1.2W ones which have the wrong base & don't want to chance the dealers charging me the earth for a tiny bulb.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Bump
    Full Member Big Sig's Avatar
    Is it a bayonet fitting?
    Could be one of these? http://www.thetoolboxshop.com/ab281-...ulb-8588-p.asp
    Or they stock a few other different types.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Sorry, not that type, they're a small grain of wheat type bulb in a light green plastic holder, similar to these but with a shorter bit of plastic sticking out at the bottom
    I seem to remember buying some of those, not too expensive iirc.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Here's a couple of pics
    The bulb is a wedge type push in bulb (on a smaller scale to the W5W wedge type side light bulbs). You can either replace just the bulb or the whole fitting. IIRC the bulb wires are spot welded to the terminals and can be removed for replacement.
    I think the code is either T5 or T7.
    Last time I bought some, I got them over the Vauxhall parts counter, complete with lamp fittings as well.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Yeah, you're right, the contacts outside the holder are soldered to the bulb contacts, but i don't really want to do any fiddly soldering, so i will probably get some from the stealers.
    You shouldn't need to do any soldering. Just pull out the old bulb and break off the wires from the contacts, then push the new bulbs into the holder as you would if changing side lights. It's effectively the same type of bulb (wedge, or some people call them capless), but on a smaller scale.
    Edit - one quick google search for 12 volt capless bulb & holder found
    http://www.ebay.co.uk/itm/BOX-10-CAP...696#vi-content
    or just the bulbs
    http://www.ebay.co.uk/itm/BOX-10-MIN...-/140536440349
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    all sorted, went to the dealers as i didnt want to fiddle around or wait for a delivery
  1. Upgrading the clock for full screen type?
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2012, 20:11
  2. Removing Radio cd30 and clock display
    By AlanT1 in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2012, 01:01
  3. Swapping clock/radio display
    By bones341 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 08:55
  4. Clock/Radio display
    By shuggler in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 23:27
  5. clock display
    By shakealeg in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2008, 17:22
replace car radio lights vectra c
vectra c clock bulb
vectra c light behind display
light for vectra c radio display
https:www.vectra-c.comforumshowthread.php149063-Radio-Clock-Temperature-display-bulb-type
vectra c clack bulbs
vectra 2000 clock screen
