Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: STILL leaking water! I'm going to scream!
  1. #11
    Chelmsford
    Quote Originally Posted by cliomjh 102 View Post
    i had the same leak, open the boot top left just at the end of the roof rail the joint cracked slightly letting water in the same place as you said by the siren, hope this helps.
    Just covered the area with a layer of decent quality electrical tape and, without wanting to speak too soon, I think it's fixed.
    On my first hosepipe test, it leaked water as usual, but I think that was because the rubber gaiter round the cables had come off when I closed the tailgate, and the water was running in through that. I've sprayed it with the tailgate open and no sign of anything inside...
    Fingers crossed it's finally sorted...
  2. #12
    Feb 2014
    Epsom Surrey
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 1800
    hi im andrew new to the site and was wondering if any one can help me with a few bit im getting water in the boot and getting a water swooshing sound the sounds like its coming from the behind the dash bored many thanks andrew
  3. #13
    Feb 2014
    Epsom Surrey
    Trim : LS
    Engine : 1800
    Default Water getting in to my boot and a swooshing noise
  4. #14
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Mazda 6
    Trim : SE L Lux Nav+
    Engine : 2.0 Skyactiv-G
    Year : 2019
    Quote Originally Posted by djrdewb1986 View Post
    For the water in the boot check the aerial rubber base see if it has perished.
    For the sound from dash check if you have wet front passenger footwell.
  5. #15
    Barrow In Furness, Cumbria
    And clear the rubber bung in the bulkhead so the water drains away.
  6. #16
    Jun 2009
    Middlesex
    Anybody drilled out the rivets that holds the black clip in place that secure the plastic roof bar trim strip running from the bottom of the windscreen to the back of the roof (Top of tailgate) ?.You know the rivets that come loose and cause a water leak.
  7. #17
    Regular Member 4eyes's Avatar
    Birmingham
    Quote Originally Posted by Dobs View Post
    I couldn't get mine out with the drill so I just hammered the heads off with a flat head screwdriver, took me 10 mins to do all 8 and I'm not particularly handy.
    Tom
  8. #18
    Regular Member MACVVT's Avatar
    May 2011
    fife,scotland
    Vehicle : vectra c
    Trim : sri
    Engine : 1.8 vvt (XE18XER)
    Mileage : 28,000
    had the same, dripping at siren box, was the boot seal,took off ,gave it a clean ,god was it dirty under the edge, reinstalled , no leaks even with pressure washer at 110 psi.
  9. #19
    Jun 2009
    Middlesex
    Do the pop rivets pull up alright and secure the black plastic tight into the channel.
  1. o2 Router leaking water
    By bigmac in forum General Chat
    Last Post: 30th October 2012, 16:34
  2. water leaking
    By jinkie in forum Engine & Drivetrain
    Last Post: 14th August 2012, 19:51
  3. Water leaking in car fix -* VIDEO *-
    By shammon in forum Bodywork & Interior
    Last Post: 28th April 2012, 19:47
  4. Oh No....Water Leaking into Boot!
    By chrisschild in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2008, 18:48
  5. Leaking water
    By peter142 in forum Engine & Drivetrain
    Last Post: 5th September 2007, 15:10
