Thread: How to adjust handbrake after fitting new pads
    Regular Member dannycturbo's Avatar
    Aug 2011
    Letchworth, Herts
    Default How to adjust handbrake after fitting new pads
    I have just fitted new rear pads to my 2.0 turbo and now the handbrake is a bit high is the an adjuster under the handbrake like the vec b or doyou tighten it up another way
    West
    Once pads are fit, push foot brake until the pads have gripped the disc, then lift the handbrake lever... they are self adjusting so you may want to repeat the process a few times... see the howto
    http://www.vectra-c.com/forum/showthread.php?t=15092
    Aug 2011
    Letchworth, Herts
    Do I have to have the rear wheels off the ground to adjust it or can I do it flat on the ground depress footbreak and then pull up handbrake
    West
    it shouldn't make any difference mate... when i replaced my discs & pads i remember it took a good few goes for the hand brake to adjust, just keep pulling it up on the ratchet & repeat for a while
    Aug 2011
    Letchworth, Herts
    Is this with the engine off or the car running or again does it not matter :-)
    West
    again this shouldn't matter matey
    Aug 2011
    Letchworth, Herts
    Ok many thanks
    There used to be instructions in the handbook for the Vectra B for this, but no longer appears
    Engine : 1.9 CDTi
    Just done this job today myself.
    It will take about 500 miles for the rear pads to bed in and the handbrake will get better as they bed in.
    Aug 2011
    Letchworth, Herts
    All done many thanks all
  1. Handbrake? is it self adjust?
    By dave1419 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2013, 12:31
  2. Handbrake adjust
    By st2malo in forum Bodywork & Interior
    Last Post: 16th January 2011, 12:47
  3. Rear Brake Pads / Handbrake
    By dnywra in forum Suspension, Wheels & Brakes
    Last Post: 4th May 2010, 21:11
vauxhall vectra 1.9cdti handbrake adjustment
olel vectra c hand brake
opel vectra c handbrake adjustment
vectra c poor handbrake after changing pads
vectra c handbrake self adjuster
vectra handbrake adjustment
how to adjust vauxhall vectra handbrake
how to addust handbreak on a vaxhaul vectra 2007 plate car
vauxhall vectra c handbrake adjust
2005 vauxhall vectra handbrake adjustment
how to adjust handbrake on a vaxhall vectra
changing vectra c hand brake
vectra c handbrake not holding after changing pads n discs
how to adjust handbrake on astra after doing rear pads
vectra c handbrake adjustment site:www.vectra-c.com
vectra c adjust handbrake
2006 vauxhall vectra handbrake adjustment
adjust handbrake vectra 2005
how do you adjust the hand brake on a 05 vectra
handbrake adjustment insignia 2009
handbrake adjustment after new brakes
how to adjust vectra c handbrake
fitted new rear brake pads how to adjust self adjusting handbrake
vauxhall vectra 2007 handbrake adjustment
