Thread: AntiFreeze
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    Default AntiFreeze
    How do I know if the car has anti-freeze in it or not? Does reddish coolant indicate Its all prepped for the winter??
    Whats the best product to use?
    Also what precautions will people be doing on their GSi's for the winter?? http://www.dailymail.co.uk/news/arti...xtra-grit.html Expecting -20 Degrees
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    Sep 2009
    luton
    Mileage : 100000
    cheers bud, definitely need to go get my self one of those
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    about 3 months ago i went in to vauxhall to buy some genuine gm vauxhall antifreeze i asked for the one for my 1.8 vectra they gave me the red/orange 1 litre bottle
    i already had the red/orange originally from new in the tank
    part number 93170402
    it is longlife and goes down to -38
    mix 50 percent water and 50 percent antifreeze
    about 4 pounds
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Yes the reddish coolant means there is antifreeze in it. The Vec requires OAT antifreeze. Although there is no official service life for this 5 years is about the minimum life span. If you are considering changing it I have found the the stuff from VX is as cheap as a motor factors.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    -20 im getting my resistor pack changed monday
    Aug 2010
    Leeds
    Got a merc in the family with coolant that is 15 yrs old never been changed and still hovers around -25 when checked which is fine for the uk.
    If you test yours and it's still in spec leave it alone unless your bored then bach flush out the radiator and the heater matrix and re fill.
    Then get a air lock and wish you had not bothered.
  1. Which Antifreeze?
    By paz_badboy4life in forum Engine & Drivetrain
    Last Post: 26th September 2012, 16:02
  2. Antifreeze
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 17:16
  3. antifreeze
    By leesri in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2010, 18:46
  4. Antifreeze
    By ed taylor in forum General Chat
    Last Post: 26th May 2009, 21:42
  5. Antifreeze
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2009, 19:38
