Results 1 to 10 of 13
Thread: Z20net gearbox
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Z20net gearbox
    Hi guys looking at giving my gearbox a make over as its a bit clunky, im experiencing clunky gear changes especially from 1st to 2nd and 2nd to 3rd you can hear it engage and is also not smooth if i do a fast change say from 1st to 2nd there is a jerky movement and a thud even if driving slowly and reserved its jerky and quite hard to ingauge sometimes is there a better gearbox i can upgrade too as im looking at replacing the clutch, thrust bearing, dual mass fly wheel and release spring i cant remember the gearbox being this clunky on my old 2003 1.8 sxi
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    when you get the clutch etc done you can have the gear oil changed and reduced to the correct amount and this will make a difference in itself..i think some guys had issues and sorted them be doing something to the gear stick mechanism..
    you have the F40 gearbox and have no other options, its one of best, albiet a little clunky for some.
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Quote Originally Posted by Caveman_nige View Post
    Thanks Nige so what can i do to the gearstick mechanism
    Jun 2009
    South Coast
    dunno what they did... but i am sure a quick search will find any gearbox related issues and fixes
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    The only other option is to realign the gears, there's a how to on here it's a 10minute job.
    Tried everything with mine and it's still notchy as hell,
    Let us know how you get on
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Where is the how 2 mate
    Mine is notchy as hell and want to get it sorted
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Simples enough to do an oil change and putting revised amount in..
    Regular Member PORKBALLS29's Avatar
    Epping
    Tbh I think the f40 is the worst part of the Vec. So notchy and clunky never owned a car with a worst gear box. In fact both of my Siggy's have been the same. There was nothing wrong with either just very notchy.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    My car is booked in end of the month at vauxhall for mot and service I'm gonna mention it when I take it. Might ask for a good gearbox oil change see if that makes a difference if it does I'll let you know as for the gearbox overhaul I'll give feedback on this aswell because I really believe if I change these parts it will be alot better but looking at doing this early next year while I save
    Aug 2011
    Basingstoke
    Trim : SRI
    Quote Originally Posted by nikroc View Post
    I meant a how 2 on the gear realignment,aparently it helps alot.I dont think mine is gearbox oil related as it doesnt get stiff when cold,just very notchy changing into 3rd from 2nd
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. z20net f40 gearbox oil
    By leesri in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 20:03
  3. z20net gearbox oil
    Last Post: 2nd November 2010, 18:08
z20net gearbox bearing kit
z20net service
clunky vectra c sri 1.8 2008 gearbox
z20net how to check gear oil
z20net oil capacity
what gearbox does the z20net have
