Thread: Radiator top mount bushes
    May 2011
    Leeds
    Default Radiator top mount bushes
    Evening all,
    I need help with replacing the above. i have sprayed the springs with WD40 for some time now but this only cures the creaking sound for a couple of weeks. i have 2 new top mounts but i just can't see how you get in to change them, do i need to take the radiator out or can this be done with it still fitted to the car. Also how are they held in it dosen't look like a bolt is holding them in, is it a pin that goes through the spring that can be pulled out.
    The car is a 53 20T Vectra
    Thanks in advance
    Phil.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    what you need to do is loosen off the lower rad mounts to allow the rad to drop down an inch. change the rubber mounts and the tighten up the lower mounts again. you will need your bumper off to do this though
    May 2011
    Leeds
    Can i drop the rad without disconnecting hoses.
    Does anyone know what holds the bushes to the rad. i have had a good look and dosen't look like a bolt. is it just a pin that pulls away.
    Phil.
    Jun 2009
    South Coast
    you can leave the hoses connected.. as stated, only loosen the lower mounts so they drop down at an angle a bit thereby lowering the rad pack enough for you to do what you need with the top mounts
  1. Powerflex engine mount bushes
    By Caveman_nige in forum Handling & Braking
    Last Post: 6th May 2012, 15:16
  2. Annoying knocking - radiator mount?
    By Celes in forum Engine & Drivetrain
    Last Post: 19th March 2012, 08:03
  3. Can top mount bearing or arb bushes rattle?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 20:40
  4. Radiator mount popped out over pothole! Any advice on how to get back in?
    By nickyg in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2009, 11:28
  5. Signum radiator bushes
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2007, 12:24
vectra radiator mount
