Thread: Spanner light, but no code.
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default Spanner light, but no code.
    Got a strange problem, the spanner light comes on and stays on at ignition until the engine is started, normally it lits up for a sec or two on ignition then goes off. So anyway i use a fault code finder on it and it came back with no codes. Odd.
    Mileage : 000
    I had that with mine. I belive it is nothing to worry about, it could just be a glitch. If the spanner light goes out when the "engine is running" and the car drives ok,then I don,t think it is anything to worry about
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Mines started doing the same thing recently, i just connect my code reader then just do a erase. Comes back after a few days to a week but everything seems ok.
    Regular Member Bigglesfliesundone's Avatar
    Jun 2011
    Darlaston
    I was told that its a low oil pressure warning from the engine start, as soon as pressure builds to what the sensor is expecting the light goes out......then again the guy could have simply been feeding me manure!
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Yeah engine runs absolutely fine, must be just a glitch in the system.
    Cheers.
    West
    It means there has been a fault at some point recently but is now not present, it can be cleared with a decent code reader... as long as the light goes out once the engine has fired there is no problem & it will probably clear itself after so many fault free starts
    Regular Member shoota70's Avatar
    bristol
    mine does this and stays on for 5 mins or so.. my mate who has a garage plugged it in and said i had a dodgy glow plug and not to change it as it starts perfect and aint causing any probs..but as soon as it takes more than a few turns to start i will get it changed
    West
    Quote Originally Posted by shoota70 View Post
    the OP's light goes out imediately after firing... totally different to your glow plug fault which will only get worse once the ice kicks in
  1. spanner light but no error code
    By danno91 in forum Engine & Drivetrain
    Last Post: 12th October 2011, 19:20
  2. spanner light with no code again
    By iasha in forum Engine & Drivetrain
    Last Post: 22nd August 2011, 16:41
  3. spanner light with no code again
    Last Post: 1st July 2011, 06:55
  4. Spanner Light, No Code, Poor MPG - WHY?
    By markluk in forum Vectra C / Signum Troubleshooting
    Last Post: 17th March 2009, 13:48
  5. Spanner Light with P1191 fault code?
    By simp_2.2sri in forum Vectra C / Signum Troubleshooting
    Last Post: 16th October 2008, 20:14
