Results 1 to 3 of 3
Thread: grinding rubbing noise
    Regular Member coooky's Avatar
    May 2011
    washington
    Default grinding rubbing noise
    On my way home from work i noticed there was a grinding/rubbing sort of noise coming from what sound like my drivers wheel
    only had the pads done a few months back and the noise is still there when applying light or heavy pressure to the brake pedal
    could it be the bearing
    whats the way to tell if a bearing is on its way out
    May 2011
    washington
    sorted it was the back wheel a piece of metal had lodged between the disc and the plate at the back some how lol
    Leicestershire
    Talking Similar problem, thanks guys
    My Vectra developed a nasty grinding noise from the nearside front wheel a couple of days ago, so I naturally feared the worst, ie wheel bearing/discs etc. It turned out to be a small stone stuck between the heat shield and disc, which fell out when I prised the heat shield away from the disc with a screwdriver.
  1. Rubbing noise nsr
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 27th December 2011, 01:05
  2. Sounds like a rubbing noise
    By Gortreck in forum Suspension, Wheels & Brakes
    Last Post: 2nd March 2010, 11:37
  3. rubbing noise/droning ?
    By bigmac in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 10:54
  4. rubbing noise?
    By Messenger in forum Engine & Drivetrain
    Last Post: 24th February 2009, 21:21
  5. Rubbing noise
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 23:56
