Thread: 1.9 cdti turbo,head gasket or piston ring ??
    New Member colinlee's Avatar
    Oct 2011
    doncaster
    Default 1.9 cdti turbo,head gasket or piston ring ??
    Hi, my name is col, i have recently bought a 1.9cdti vectra elite (120) and must say i am / was very happy with it, very soon after buying it i realised it was/seemed to be under powered.. and with thanks to this forum i managed to sort it out.. EGR valve removed and sorted thanks to all the good posts on here..
    Now then, we get to the title subject matter, hopefully someone can help me identify a probable cause of my recent breakdown.. whilst driving home from work not hammering it, but i must admit to being a touch... shall we say vigorous.. there seemed to be a little bit of turmoil under the bonnet then a sudden loss of power.. very difficult to rev, virtualy no pull or power.. the spanner light flicked on twice but then went off, after more or less freewheeling until i could pull over (was on town centre road) i finaly stopped only to be overtaken by a large cloud of smoke !!!
    I stopped the engine popped the bonnet expecting the worst..nothing much amiss ??? fired her back up, hey presto... large plumes of smoke. Thought better of it and left the car until the morning when i could get it recovered back home..
    Now then.. there is no loss of coolant, no mixing of water or oil in either the filler cap area, expansion tank or indeed on the dipstick.
    the smoke is mainly white in colour with a possible tinge of blue, the smoke is barreling out the exhaust with some whisps of smoke from both the filler cap area and the dipstick tube.
    there is also oil leaking at what looks like a flexible mesh type union on the exhaust ???
    I pressume that it could be the head gasket or the turbo or even a piston ring problem, my question is in you opinion which is the more common and what other problems could these produce.. also if anyone has had the same problem what were the costs of repair just so i have a ball park figure to go into shock with !!
    I believe it is the z19dt engine (120) and its on a 04 plate elite, with 107000 miles on it, the timing belt was done at 100000..
    Any thoughts or information would be helpfull.. Cheers.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If the engine oil filler cap is on the left its a 120, if its on the right its a 150, either way it may pay to remove the large hose on the right hand side, look for loads of oil or metal swarf unfortunately it could be the turbo,
    inter-cooler-throttle body pipe 150 shown in this thread below, & the 120 shown in the attached pic.
    http://www.vectra-c.com/forum/showth...=107034&page=2
    Oct 2011
    doncaster
    Thanks Wizard... Yeah it's deff the 120, that much i found out when i did the EGR valve... at the time i was unclear if it was the 150 or the 120, luckily it was the 120 and i didn't have to worry about the swirl flaps..
    But yeah, will deff remove said hose and check it out.. i was hoping it was just the head gasket, but i too think it is the turbo.
    Do you know of there ever being piston rings going these cars or is that problem few and far between ???
    Once again cheers for the advice.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    To be honest not heard of ring problems but you do hear of turbo problems, If you have oil in the exhaust flexi cant be good.
    Regular Member FatboySteve's Avatar
    Bedfordshire
    Turbo, especially if there's oil leaking from the exhaust flexi!!
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as above sounds like turbo bud i think you will find play in the turbo bearing when you check it
    Oct 2011
    doncaster
    Thanks for the advice gents.. any ideas on costs just as a ball park figure.. it'll be a local Vx specialist doing the work.
    Col.
    Oct 2011
    doncaster
    had pipe off... loads of oil, far too much by my reckoning.. yup, looks like turbo gone... cheers fellas.
    Aug 2013
    West Sussex
    Vehicle : 1.9 CDTI
    Trim : Elegance
    Mileage : 124000
    How much to fix it lee? Back on road?
    Admin plasma's Avatar
    On the Forum
    259 Post(s)
    Engine : 150
    Mileage : 74000
    turbo is easy compared to a head gasket, 2nd hand turbo for about £150-£200, few gaskets and 4hrs or so to change it over. Dont forget the flushing of the pipes and intercooler though
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. Head gasket ?
    By mrpoochie01 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2012, 15:55
  2. New owner - V6 CDTI - Head gasket??
    By Bigv in forum Engine & Drivetrain
    Last Post: 13th July 2011, 13:58
  3. piston head link
    By kirky2k4 in forum General Chat
    Last Post: 18th March 2011, 16:47
  4. ? head gasket, vectra c 1.9 cdti 150
    By DLIVI223 in forum Engine & Drivetrain
    Last Post: 2nd March 2011, 22:59
Sri cdti 120 head gasker
vectra 1.9 cdti 120 turbo problems
vectra cdti 150 piston rings
vauxhall vectra 1.9cdti z19dt standard piston rings
1.9 cdti head gasket
vectra c diesel head gasket
changing head gasket on vectra 1.9 cdti
wauxhall vectra 1.9 headgasket
vectra 1.9 cdti head gasket
changing head gasket vectra c 1.9cdti
vectra c piston ring failure
cdti 150 head gasket kit
vectra c 1.9 dti head gasket
Vectra c 1 9 cdti 120 head gasket failure
120 cdti piston for sale
vectra c 1.9 head gasket
vectra cdti gasket
