Results 1 to 10 of 11
Thread: Changing Spark Plugs
    Barrow In Furness, Cumbria
    Default Changing Spark Plugs
    How easy is it to do on a 1.8 SRi (VVT) and what does the gap need to be set at? I'm getting the plugs from VX so could they be pre-gapped? Thanks.
    WGAF#5
    on a i.8 should be pretty straight forward ... make sure you have the correct tools and take your time .. you dont want to snap a plug off
    and to answer the question .. yep the plugs SHOULD be pre gapped if purchased from VX (and anywhere else if the correct type purchased)
    good luck
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved
    Irmscher Insignia CDTI 130
    11 Post(s)
    Plugs should only be regapped if they're single electrode, but they should come from manufacturer already correctly gapped.
    If they're mutli-electrode then any attempt at regapping can prematurely wear them out as the spark will always take the shortest route and wear out one electrode quicker than the others.
    As to changing them, I can't imagine it being much different to the 2.0 engine that's mentioned in the HOW2.
    Cheers.
    Oct 2011
    SHEFFIELD
    very easy, unbolt the rail coil on top of the rockerbox, pull the rail coil up and the plugs are down the top of the cylinder head, a 12mm plug socket & a long extension required. when putting them back i always put a dab of copper slip on the thread. DON'T over tighten them just a nip after they get tight.
    Jul 2011
    UK
    Hardest part I found was getting the coil off the plugs in the first place.
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    not worth getting iridiums? i got the same car and put them last week.
    Apr 2011
    Southport
    Quote Originally Posted by motorbits View Post
    Mine were 10mm.
    Feb 2011
    Selby
    Some 1.8's got iridium sparkplugs from the factory
    (oh all right, the Dual Fuel ones did, because LPG needs a stronger spark)
  1. Is there a How To for changing 2.8T spark plugs please ??
    By Signumv6man in forum Engine & Drivetrain
    Last Post: 15th July 2012, 08:42
  2. Changing spark plugs 2.8T
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 14th June 2012, 12:28
  3. What Spark Plugs
    By Rebellion8878 in forum Engine & Drivetrain
    Last Post: 8th January 2011, 19:38
  4. Spark Plugs
    By lizard in forum Petrol Engine related
    Last Post: 4th April 2010, 10:36
  5. spark plugs!!
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 15:50
