Thread: CIM modual broke???
    Jun 2011
    Birmingham
    Default CIM modual broke???
    Hey there folks, Im new to car forums, so I hope your all clued up and feeling helpful!!
    My Vec C 05 plate with 97k miles is showing traction light and power steering light also. The ABS is working on braking fine however i can get the wheels to spin, which was impossible before the lights came on. The power steering is occasionally a bit heavy, but perfectly drivable.
    Im told this is something to do with the column interface module which lives under the steering wheel. Before i go down the road of replacing this, are there any other problems i need to rule out first.
    Many thanks...
    Jun 2011
    Birmingham
    Bump!!!
    north east
    Passenger side fuse box pull out fuses 17 and 26 leave them out for a few minutes then put them back in, fuse 10 is for the steering colum so may as well pull that out while your thier.
    Another thing to check is take the plug off the ABS modual under the bonnet and spray it with wd40.
    Gloucester
    Did this sort out your problem? I have almost the same. Steering is a little heavy when I need to turn quickly, and the tyres light up now!
    Yours Simon M.
    Gloucester
    Yours Simon M.
    Oct 2010
    Lincoln
    Do you have ESP fitted? If not then it's a cheap fix if you have - like me then it's about £450. Difference is that with ESP, the SAS (Steering Angle Sensor) is part of the CIM itself, without ESP it's fitted to the steering rack. Reason I know all this is that I have those lights on and that's what the garage told me. They even showed me the Tech2 display showing bad data from the SAS as the wheels were turned. Car still runs fine so I'm leaving it until it either becomes undriveable or I've got some spare cash
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Same as mine, did you ever fix it?
  1. Another PS3 broke
    By simmo3187 in forum Games Room
    Last Post: 15th March 2011, 21:12
  2. My car is broke !!!
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2011, 00:04
  3. Just broke broke bit of my dash
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 17:15
  4. Broke me car!!!!!
    By Jay Kay 313 in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 07:23
  5. Car is broke again....
    By JonR in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2008, 14:14
