Thread: Help! Seat belt won't unwind!
    Chelmsford
    Default Help! Seat belt won't unwind!
    During my day of playing "find the water leak in the boot, I unbolted the left hand rear seat belt mechanism from the bodywork, so I could feel behind it for damp.
    Went to refit it today, but the ****** thing won't unwind! It's fully wound up and won't extend so that I can put it back in place! Any ideas?!
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Have you tried pulling on it at different angles, very gently, or pull, release and pull? Mine lock up on sharp bends and other inconvenient times.
    Regular Member fingers66's Avatar
    Carpe Diem
    Mines was the same .... I just gave it a BIG tug ....been ok since then ....
    newport
    if the back of the seat isnt locked into position, the seat belt wont unwind, could it be this causing the problem?
    Chelmsford
    Taffy, it's not the middle seat mate, but I've had that problem before (when I put a leather interior in my Vec B). Thought the belt knackered!
    Managed to solve my problem finally, having taken the mechanism to pieces to see how it works...
    It's got a big ball bearing in it, which when incorrectly positioned, jams the mechanism and causes the belt to lock. When it's correctly positioned (ie: when bolted to the car) the ball bearing sits in a small recess, so the mechanism gets the clearance it needs to work correctly. If the reel is wrongly angled, even by a couple of degrees, it won't unwind.
  1. Rear seat stuck down due to locked seat belt
    By Brad_The_Yid in forum Bodywork & Interior
    Last Post: 15th May 2010, 13:22
  2. seat belt light and seat occupancy recognition
    By xc600 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2010, 20:26
  3. Seat Belt.......
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2008, 00:16
  4. Seat belt
    By tubby in forum General Chat
    Last Post: 22nd July 2007, 11:39
  5. seat belt
    By paul429 in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2007, 20:31
seatbelt wont unwind
new seat belt wont extend vauxhall vectra
unwind seatbelt
https:www.vectra-c.comforumshowthread.php148901-Help!-Seat-belt-won-t-unwind!
corsa seat belt wont unwind
