Results 1 to 10 of 24
Thread: How can I turn OFF Parking Heater
    Regular Member Maxim007's Avatar
    Jul 2009
    Bistrita
    Default How can I turn OFF Parking Heater
    Hello all...
    Just want to find if I can somehow to turn my parking heater off...
    I mean every time when i start my car and outside are below 8 degrees C it turns ON himself...till the engine temperature reaches 80 Degree C...
    So my question is if I will pull off the plug from mine outside temperature sensor...will it still starts HIMSELF???
    Does anyone knows if he "smell" the outside temp trough our sensor from front bumper? Or he take it from some of Engine Coolant Sensors???
    It is now really annoying to hear it if I don't want that (to turn it ON)...
    Or can i UNPLUG ONLY one of the wires from the plug which is connected parking heater in order to DO NOT START ANYMORE HIMSELF...Only manually start...I mean to interrupt the communication between PARKING HEATER and one of those sensors...i think that will be the easier way...
    I still need it to turn it ON...But ONLY MANUALLY...(when I need that) from the climate panel...
    So is here someone (electrician) who knows which wire i need to cut from main PLUG from parking Heater???There are a lot of them...maybe 10-12...
    1 - fuel pump
    2 - glow plug
    3 - fan heater
    4 - engine coolant sensor (to know when to stop )
    5 - Outside temp Sensor (to know if to start or not HIMSELF )
    6 - timer plug
    7 - water pump
    and a couple more.
    Now I need to know EXACTLY which one of them is exactly the Outside AIR temp Sensor??? in order to "cut" it...
    Because I think if i unplug directly the plug from SENSOR from the bumper...I will newer see which temperature is outside on my DISPLAY...
    So my Little question is only about that Main Parking Socket....and which one of all that wires i can CUT?
    So please any answers will be appreciated...
    Thanks..
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    We dont have them fitted to our cars in the UK mate. Although if Kemp finds this thread he should be able to help you.
    Jul 2009
    Bistrita
    From which I know....all opel/vauxhalls has the same "extras" (parking sensor, rain sensors, heated seats, alarm, PARKING HEATER)...some of them has more extras...other ones has only a couple/or without "extras"...and Parking Heater is only an OPTION of the car...i mean someone when buy it (the car) from new...if he needed that parking heater as an extra for his car, he can pay some more Euros/Pounds and he get it...
    So i think even on the UK cars that parking heaters are fitted...
    (and I mean an genuine one...not a WEBASTO aftermarket)
    Thanks...
    East Ayrshire
    Trim : SRI XP1
    nope. All the things apart from the alarm are at an additional cost here in the UK. So most do not have them
    Unsure what the parking heater is tho
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Like u have just vein told we don't have them here when kenp sees the thread he might be able to help we don't have very coldl winters so our cars to don't have park heaters
    Jul 2009
    Bistrita
    Hello again...
    yesterday i have unplug that "big" socket from the Parking heater and that is a socket with 8 wires...
    From all that 8 wires I have only 4 of them only...
    1 - Red.
    2 - Black
    And other 2 are a little thin but i cannot tell you color of them.
    So with all that how can I make it to WORK only by programming it...
    I din't want it to start everitime when i start my engine and outside temp is BELOW 8 degree...?????
    It is now really annoyng...(with that dense SMOKE under my car...).
    many thanks (KENP )
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    well the parking heater on opel is Eberspńcher and webasto ... soooo still aftermarked even OEM fitted.
    You can have it Tech2 off. but why do you want it removed. as it actually help your motor live longer? (you actually also have to start it sometimes during the summer time to make sure it dosnt bread)..
    but if you remove the plug for it.. then it wont work
    Engine : 2.2 Direct
    Red/black is live and ground
    the 2 others its for telling when to start .. let me guess you also have ECC (climate control) if you have you can in that also tell the car when to start..
    (forgot besides taking the plug off you could also remove the fuse...)
    S.Shields (Newcastle)
    The insgina I have does that!! mostly makes me mad as!
    Jul 2009
    Bistrita
    Quote Originally Posted by kenp View Post
    Many thanks KENP...
    I tried already booth options (unplug the socket from it...and take the fuse off)...EVEN i disconnected the plug from rear little "dossier pump" which give fuel in Parking heater...
    In all 3 situations i found that my board computer is DIED! (only a BIG F appears in stead of numbers of KM.)
    I don`t know how many miles (KM in my case) or even the instant consumption, or average consumption...all are DIED.
    i don`t know how they are linked with that info? I mean if I take off the FUSE (which is for parking heater) why I loose the rest of INFO from board computer?
    and IT works...because the smoke (huge smoke) still persist...
    And maybe you know how worth is with that smoke under you car...in the morning
    so maybe (my last option) I will insert a piece of potatoes in the exhaust of the parking heater... maybe than IT will realize that I don't need it to run without my PERMISSION...
  1. It Is Now My Turn
    By RobW in forum General Chat
    Last Post: 16th August 2011, 22:22
  2. My turn - What's in the box?
    By Ian-Highlander in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 18:34
  3. Ha ha ha my turn now
    By neilb1 in forum The 'Off Topic' room
    Last Post: 15th March 2011, 21:50
  4. Oh.......my turn now!!!
    By Caterman in forum General Chat
    Last Post: 23rd August 2007, 18:46
  5. Must be my turn...
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2006, 17:42
opel vectra c parking heater
vectra c ebersp├Ącher turn on
opel signum turn webasto on
insignia eber fuse
how to turn off the parking heater
insignia auxillary heater
opel vectra webasto controll
vectra c enable parking heater
parking heater opel vectra c
opel vectra c parking heater installation
vectra c vebasto control
smoke auxiliary heater vectra
vectra c parking heater www.vectra-c.com
webasto programering opel vectra
https:www.vectra-c.comforumshowthread.php148900-How-can-I-turn-OFF-Parking-Heaterpage2
opel signum webasto how turn on
insignia heater eber fuse removing
