Thread: Sub rca wiring
    Sep 2011
    kent
    Default Sub rca wiring
    Morning people!
    Just wondering how people have wired in their Subs but using the standard head unit? Am i right in thinking I need like a Speaker cable to rca converter? if so, wheres best to run it from and how would I connect the remote cable to the amp?
    Sep 2011
    kent
    anyone?
    Regular Member jimmywhu's Avatar
    Sep 2011
    essex
    im sure someone will bealong soon to help mate
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Has your amp got a high level in put mate if not u will need to put speaker to RCA converter mate I have done it with my ncdc2013 and on a few other cars aswell
    Sep 2011
    kent
    Yeah it has got a high level input, never used it though lol! where does it run from? an if i end up using an rca converter, where in the rear speaker cable loom is best to cut into?
    Sep 2011
    kent
    Right, managed to tap into the rear speaker loom either side and got it all to the boot nicely, given it a quick test an it sounds so bassier than before??? head unit bass level is on -1 and the gain on the amp was just off of minimum and it was real bassy? before i had the gain just over half is this because its running on a different output than normal?
    Also, wheres best to hook the remote wire too? tia
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Fag lighter mate for the remote
  1. Tow Bar Wiring Help Please
    By countduckula55 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2012, 10:55
  2. Wiring help please?
    By Danwells72 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2010, 23:13
  3. I need help with wiring.
    By gibbon7000 in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2009, 00:41
  4. Sub Amp Wiring kit
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2009, 22:32
  5. Tow wiring
    By amiddleton in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2008, 07:57
