Thread: Finally fitted Aux input to my stereo!!
    Feb 2011
    Default Finally fitted Aux input to my stereo!!
    After buying the kit off ebay over 6 months ago I finally got round to fitting it recently to by 2006 Siggy. I carefully followed the instructions provided and patiently soldered all the components. Made a couple of **** ups along the way but got there in the end. Tonight I finally sat in the car, plugged in my iphone and listened to some tunes. Am so happy I thought I'd share it with you all. Especially as it was from reading threads on this forum that convinced me I should have a go.
    Also an oportunity to say thank you to yysnet for all his help (and patience!), much appreciated!
    If anyone is thinking of doing it, is average at soldering, has the right tools and a lot of patience, then go for it!
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Good work!
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    hhmm i havent heard of this before.
    is the kit expensive?
    i presume it can be fitted to an 07 estate also?
    Regular Member dannycturbo's Avatar
    Aug 2011
    Letchworth, Herts
    As above is the kit expensive and where did you get it from.
    Regular Member Grumpybob's Avatar
    May 2011
    Sunny Grangemouth
    The kit is about twenty quid on eBay but you do need other bits n bobs and may need Tech2 work done. Here is the item no. 330619534164
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Which HU do you have mate?
    Feb 2011
    I have a CD70. The kit is the one identified by Grumpybob above on ebay. Supplied with step by step instructions with photos.
    As also eluded to, there is a few other bits that also need to be done. I did it in this order:
    - Got latest firmware DVD from Vx dealer and updated the firmware on my CD70. This added the option of 'Aux' on the screen where you select FM/AM/CD etc.
    - Bought the kit off ebay as already mentioned
    - Bought the tool to remove the stereo HU off ebay (about £1.50) and bought a 3.5mm stereo jack socket from Maplin (also about £1.50)
    - Remove the stereo and completely dismantle it on a work bench with good light, suitable tools and a lot of patience, as per the guide provided to get down to the main circuit board. Then with a fine tipped soldering iron solder about 20 micro-components (resistors, capacitors and a couple of micro chips all provided) onto the circuit board as per the instructions. Then put it all back together.
    - Mount the 3.5mm socket somewhere on the dashboard. I put mine at the back of the bottom storage tray which sits under the heater controls so that I can plug in a lead with a 3.5mm plug at either end and my ipod sits in the slot. Then wire the back of the 3.5mm socket to the back of the stereo using the cables provided in the kit and as explained in the instructions.
    - Put everything back together, plug it in, sit back, cross your fingers and hope for the best! Da daaaa
    It not that difficult if you're reasonably good at that sort of thing, and it took quite a while, but it was worth it in my opinion.
    Feb 2011
    Quote Originally Posted by J P S View Post
    I would have thought so if it's the same head unit and doesn't already have an aux in.
    Jun 2011
    gloucester
  1. finally fitted
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2011, 19:20
  2. how many have the rear stereo fitted
    By Brake buster in forum Electrical & ICE (including SatNav)
    Last Post: 16th July 2010, 18:37
  3. Stereo fitted but....
    By Itsallrover in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2008, 22:59
  4. Upgraded Stereo Fitted
    By kizalini in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2008, 17:03
  5. Fitted New Stereo Today
    By R13hard in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2007, 15:12
