Results 1 to 10 of 11
Thread: Need urgent reply !! I'm gettin rained on!
    Regular Member Hendry02's Avatar
    Liverpool originally from Hartlepool
    confused Need urgent reply !! I'm gettin rained on!
    I've took the cover off the bottom of my signum 120 1.9 cdti to do an oil change, where is the oil release as I need to do an oil change??? Pics and advice needed - cheers guys!
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    13mm bolt in the sump and a 32mm plastic filter housing at the back.
    Admin plasma's Avatar
    On the Forum
    259 Post(s)
    Engine : 150
    Mileage : 74000
    Back side of sump (facing the bulkhead) in the middle of it. If you need to ask that are you sure you should be doing an oil and filter change as changing the oil filter is a right pig/pain to do?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Glasgow
    If you cant find a sump plug you should'nt be doing it.
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    Quote Originally Posted by byebyeitsagsi View Post
    brumie brum brum
    Quote Originally Posted by Hendry02 View Post
    If you don't know where the sump plug is then you probably don't know what size it is. So there is noway you could of started the job ensuring you have the correct tools to finish it.
    Put the bottom cover back on, go inside and search the very big very detailed "how to" section on this forum.
    Edinburgh
    make sure you use a good quality six sided socket. Sump plugs are made of toffee.
    Glasgow
    Quote Originally Posted by damers2000 View Post
    I was looking at it with an eye on the guys safety. If he cant find the sump plug next he could be jacking the car up with the emergency scissor jack lying underneath it and god forbid the car lands on top of him.
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    rolleyes
    Leave it till weekend mate, not the sort of job you want to be p****n about with tonight. Read up on the job and prepare yourself ....
    Found it in the end, deffo needs putting on the ramp as the previous owner has mangled it to bits, looks like he's even hammered grooves into it and got it off with a flat head screw driver! Oh well looks like an expert will have to sort it out in the morning!! One less beer for me at the weekend but rather that then a Car on my head, last time I herd that's doesn't go down well :-p
  1. the problem nobody can find!!!! REPLY URGENT
    By nickvectra in forum Engine & Drivetrain
    Last Post: 22nd June 2009, 11:10
  2. Replies: 6
    Last Post: 16th January 2008, 22:20
  3. Gettin rid
    By neilshaw1980 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2007, 18:04
  4. Quick wash before it rained
    By VinnyJ in forum Quick Photo Album
    Last Post: 29th July 2007, 21:44
  5. gettin old ???
    By bobbyboy in forum General Chat
    Last Post: 23rd June 2006, 10:47
