Results 1 to 10 of 17
Thread: Veccy 3.0l v6 cdti problems
    Regular Member SRI_STU's Avatar
    Nov 2009
    solihull, birmingham
    Default Veccy 3.0l v6 cdti problems
    Ive recently bought a v6 cdti ex plod, i know i know, i shouldn't have
    It runs like a absolute sack of s++t
    It runs lumpy as anything and when driving say 30mph in 3rd or 4th i can feel it juddering. Feels like im going too slow for that gear.
    When i pull up i always leave it running for around 20 sec's b4 i turn it off, but after 10 seconds it makes a click and then runs really bad.
    its a manual version with 78k
    when i give it some welly it goes like stink with no problems at all
    Anyone had any problems with there v6.
    Any help would be much appreciated
    What MY is it?
    Which engine is it, Y30DT or Z30DT?
    Intial diagnosis is it may be a blocked SCV, so what does it rev like at idle?
    If you drive through the revs without changing gear, what is it like?
    As soon as you set a speed on the cruise control, what happens?
    If weather permits, drive at about 40mph with the drivers window down
    What does the turbo sound like?
    Nov 2009
    Hi mate, its a 2007 07 plate, as for engine im not sure how do i tell.
    On idle it ticks over really lumpy but revs up fine, being police spec it doesn't have cruise. turbo sounds like something off a 800bhp skyline, whistle's its tits off but pulls well.
    cheers
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I don't think SCV's operate in the low gears. I have a lumpy idle at the moment, i think it's an injector issue.
    Sep 2011
    MILTON KEYNES
    Quote Originally Posted by SRI_STU View Post
    juddering could be dmf,
    idle could be idle control valve is knackered or excessive injector return - get a garage to do a spill test - dont get charged more than 1 hours labour though!!
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    rolleyes
    Not really sure??? but the loud click you hear maybe the electrically operated EGR valve, as you say it begins to run badly shortly after. Sounds like its a Z30DT, my Vec c is X London Metropolitan Police and when i got it, it was a total s**t tip cosmetically battered. Mechanically it was sound and its been a good car over the 3 years i have had it, just had to change the SCV,s recently and the timing belt, hope you get it sorted, and you get as much fun as i have had with mine..
    As a 2007, it is more likely to be a Z30DT
    This will form part of the start of the engine code, either on the data panel on the drivers door pillar or on the V5
    Idling, what revs is it at?
    If you watch the needle, is it complete steady or does it move?
    It could be the first signs of a blocked SCV, typically starts at higher speeds but if it has been there a long time can affect driving as slow as 20mph in first gear
    Usual sign when the SCV is completely blocked is the turbo continually spooling on, off, on, off, on, off
    It could also be a failed DMF
    On mine I found that with the engine on idle you can feel a very slight vibration through the front seats but disappears once under power
    However, when trying to accelerate there would be extreme hesitance and in some cases loads of revs with no change in speed (ie clutch slip) then suddenly the clutch would apply when the revs had reduced
    Here is what I would do
    Phone or visit three local mechanics
    Ask if they have experience of this car, a Vectra with an Isuzu Z30DT engine
    Demonstrate the issue to them
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    I had the same issue, when idling, it would idle fine for 10 seconds, then it would 'click' and then limp mode would kick in.
    The Z30DT performs a Small Quantity Learning check (SQL) to attempt to compensate for worn injectors, this is what was causing my problem, there is a field remedy that a dealer/VX specialist can apply FR2227 I think, this resolved my issue.
    Mar 2011
    North Lancashire
    The problem with my V6 cdti manifested itself when pottering along in a traffic queue or in a parking lot (between tick-over and 1500 rpm). The engine ran lumpy and on some occasions the spanner light comes on and the car goes into get-you-home mode. Stopped, switched off - problem solved until the next time. Goes like the brown stuff off a chrome shovel despite this and diagnosed as sticking (blocked) EGR valve by local main dealer. Hope this helps.
    Nov 2009
    hi all, thanks for all the advice.
    Im not getting any eml but sometimes and only sometimes the turbo stinks of oil ( reminds me of my rs tubo and cossy days)
    Im going down to vauxhall tomorrow to see what they think.
    im hoping its something simply like yours was lee, i will pass the details of what you said on to them. cheers for that
    m8internet, i initially thought it might be dmf related but praying its not.
    I'll let you all know how i get on.
    cheeRS
  1. Advice please on my veccy / problems with manifold
    By eraser2002 in forum Engine & Drivetrain
    Last Post: 7th June 2010, 07:06
  2. More problems with my Veccy
    By jonnynufc in forum Engine & Drivetrain
    Last Post: 9th March 2010, 14:13
  3. Veccy brake problems
    By toughmat in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd June 2009, 16:41
  4. Veccy brake problems
    By toughmat in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2009, 19:49
  5. veccy problems
    By Alec in forum Diesel Engine related
    Last Post: 2nd March 2008, 14:34
vectra 3.0 cdti problems
isuzu 3.0 v6 diesel engine problems
vauxhall signum 3.0 v6 cdti common problems
isuzu 3.0 v6 cdti
opel signum 3.0 v6 cdti problems
3.0 cdti problems
any problems with vectra 3.0 diesel
isuzu v6 diesel pulley problems
v6 cdti problems
vauxhall 3.0 v6 diesel engine problems
vauxhall vectra 3.0 v6 cdti sri problems
vectra v6 z30dt cdti problems
vauxhall 3.0 cdti problems on idle
vectra v6 diesel problems
known issues with 3.0 cdti
idle needle jumping 3.0 cdti
3.0l v6 cdti
