Thread: Heater constantly hot. Help?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Default Heater constantly hot. Help?
    Anybody had this before or any idea what it could be? All worked fine when went out first thing.
    Then went out again a dinner left friend in car and god nose what he has done. But since then car is stuck on hot.
    As in all the heater controls work. All fan setting direction setting etc.
    Air con kicks in when turned on. But obvisouly doesn't blow cold because heaters seem to be stuck on maximum hot.
    It's stupidly hot and cant get it off. As an idea how hot it is my iPhone went man down saying temperature and a warning wen a was using the sat nav
    Everything else works fine temp on car is ok.
    Please help with ideas as I'm not looking forward to 260 mile drive home if a can't fix it before Friday
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Sorted, well not sorted but found fault.
    My heater flap was stuck so it's unclipped ATM so at least I've got cold air and not hot
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Well done bud, not heard of the flap sticking before. Had something broke?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Tbh I'm not sure yet. As was pitch black an was doing it with the light off my phone so will try get a good look tomorrow.
    Am guessing just the electric part has seized up. As when a popped the plastic arm off I could move the flap an change from hot to cold and back again.
    So I've just left it like that for now. So if a cant find the actual fault and if needs be my mate can adjust the heat on way home lol
    Am hoping to get it off an just clean it an refit. Fingers xd
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Have a look here mate happened on mine the motor jammed I took the arm off and turned the heater control whilst applying pressure to the motor arm and it freed itself and has been fine since for over a year now.
    http://www.vectra-c.com/forum/showth...t=heater+blows
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Cheers for that mate. Just read through it. And the guy that mentioned about side light bulb. I have bulb warning from fitting led side lights. So maybe coindence a don't no will see how I get on clipping it back on tomorrow an will be buying some resistors for the lights when I get home.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Well got a better look today an seems the motor was seized solid, so managed to strip an clean the motor. Now got it working but will now only go about a third off the way to hot until starts clicking.
    Vxl want £109 :O for a new one
    So looks like am spending sat morning in scrap yard
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Got a motor from scrappies for a fiver and all sorted now :-)
  1. Tail lights constantly on...
    By Neve'o in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2016, 20:13
  2. Air con hissing constantly after re-gas
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2012, 13:22
  3. Heater constantly blowing hot!!!!!
    By axelf in forum Engine & Drivetrain
    Last Post: 29th March 2011, 16:44
  4. Internal Fan / Heater Constantly on !
    By avitohyes in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2009, 21:36
  5. Radiator fan is constantly on, anyone help?
    By fuzzbomUK in forum Engine & Drivetrain
    Last Post: 29th November 2008, 18:46
vectra heater stuck on hot
vectra c heater stuck on hot
