Results 1 to 10 of 13
Thread: Aerial base perished!
    Chelmsford
    Default Aerial base perished!
    Hi guys,
    Spent the past hour removing bits of the interior of my hatchback so I could remove the aerial and find out if it was the cause of my water leak.
    The base rubber is perished as usual, anyone know where I can get a replacement? I hear the rubber seals aren't available and a new aerial from the stealers will cost a bomb.
    I'd fit a generic or shark fin aerial, but the hatchback has the washer jet built into the aerial base...
    Regular Member bubba's Avatar
    Sep 2010
    BELFAST
    im getting my roof vinyled black and my seal is not the greatest, also found same problem no chance of getting a seal alone, depending on model between £30-£90 from stealers, £20 from breakers (possibly with another scrap seal.
    how about a piece of rubber and trim a gasket yourself?? would this work?
    chances are itll get a smidge of black silicone too just to make sure??
    Worksop
    U only need to pull roof lining at back to get to it
    VIP-Member puppet's Avatar
    East Ayrshire
    9 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Mine is headng towards goosed too, interested to see if you can get a replacement somewhere.
    Regular Member srikev's Avatar
    Jun 2011
    Chester
    Vehicle : Vectra c
    Trim : Sri
    Year : 03
    Mileage : 105,000
    Why not just use window silicon ?
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved
    Irmscher Insignia CDTI 130
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Aerial base part number is 24437021, GPS showing 1 at £24, so expect it to be £30ish from the dealers.
    Feb 2011
    Selby
    Mine's looking a bit grotty, but I'm not paying £30 when all that's needed is new rubber seal.
    I reckon we should be able to revive the seal. Maybe remove it before it deteriorates too much, sand it gently to remove the sunlight affected layer of rubber, then give it a coat of paint on the outside to prevent further UV damage (masking off the sealing areas obviously!).
    Failing that, I'm off to cut up an old door mat
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Why dont u just flush roof, and have none at all and seal a rubber bung in the hole?? Is the rear jet wash really that important? Cars look nice with no aireal.
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by Jow20 View Post
    Then howz he gonna listen to Terry Wogan?
  1. aerial rubber seal perished, where can i buy replacement?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2013, 10:16
  2. Aerial perished
    By geeza_uk in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2012, 22:11
