Thread: Diesel smell in cabin? Picture enclosed
    Oct 2010
    Northamptonshire
    Default Diesel smell in cabin? Picture enclosed
    Now and again i get a diesel smell in the cabin. Normally on hot days or long journeys.
    Last night i changed the injector 3 connector as per the help thread on here and i noticed this;
    What is it? DPF? Liquid on and around it i think is diesel?
    That's fuel filter mate - probably the seal has gone slightly or it's not on tight enough. If you run the engine and watch it you might see the fuel leaking as it's under pressure at all time from the tank pump...
    FYI, the DPF is in your exhaust, if you have one...
    Oct 2010
    Northamptonshire
    Quote Originally Posted by Penfold101 View Post
    Cheers for the quick answer. Can i just unclip it and tighten by hand? If the seal has gone can i unscrew and replace or is it a new unit (hope not)
    It's horrendously tricky to treplace actually - VX came up with a rubbish design. My personal answer would be to take it a garage and get them to change the filter. This will come with a new seal and they'll have the proper tools etc, as unless it's really loose the collar which holds it all together will be impossible to get off without taking the whole thing out of the crash box...
    Oct 2010
    Northamptonshire
    Ok. Now i had a major full service in March this year including cambelt etc. i assume they would of replaced the fuel filter then as standard practice?
    Quote Originally Posted by Dan_W View Post
    They SHOULD have, but there's no guarantee of that. It could be one of the blue pipes going into the filter too, so it's worth having a look first with the engine running to see if you can see anything. In fact, you don't even need the engine running - just ignition on will pressurise the system...
    Oct 2010
    Northamptonshire
    Ok, im going to check my invoice after work to try and confirm this. Failing that i will ring and ask would they normally change it on a
    Full service. If they would then i may be able to get them to sort it. I've probably done 10k miles since the "service" in March this year so surely the FF shouldn't of failed?
    It should be changed on a major service, but regardless of what the invoice says there will be no way to tell if it was actrually changed or not - especially after 10,000 miles. It only costs a tenner, 15 quid fitted possibly.
    Oct 2010
    Northamptonshire
    Oh really, lol i was expecting more! Cheers for your help man
    No worries mate - let us know what happens...
  1. Eggy smell in cabin....what could cause this?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 19:38
  2. Ammonia Smell In Cabin
    By PORKBALLS29 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2011, 19:32
  3. Smell in Cabin....
    By unreal_event_horizon in forum Engine & Drivetrain
    Last Post: 1st February 2011, 00:57
  4. Fumes smell in the cabin
    By Northy in forum Engine & Drivetrain
    Last Post: 17th January 2010, 19:59
  5. Is This Engine 120bhp or 150bhp cdti Model? (picture) enclosed!
    By Longtallhowie in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2007, 23:18
vectra diesel smell in cabin
