Results 1 to 10 of 22
Thread: Winter Tyres
    Fife
    Default Winter Tyres
    Thinking bout winter tyres especially since last winter was a bit of a disaster and this winter my fiancé is gonna be driving for the first time (she has her test soon) Just wondering if anybody knows when the best time to have them fitted is? also any recommendations of a good winter tyre?
    Aug 2010
    Leeds
    End of this month and for the next 6 months if you beleive Auto Express.
    Though they do say a hard winter is coming and these winter tyres work best below 7c.
    Hurry up as when it comes they will be flying off the shelves.
    Fife
    thats why i was looking in to it now, thanks for reply mate
    As luck has it my front tyres are usually down to 2mm at this time of year
    I usually wait until the roads are heavy with leaves, which results in blocked drains, standing water, and floods
    If I still have 4mm of tread on the front tyres I then wait until the first snow and then buy two new tyres and place the removed tyres into storage
    These new tyres are usually enough for me for the next four months, when worn down to 4mm the snow has usually ceased, and once worn the previously stored tyres can be refitted and worn out as well
    On the Vectra C there is no point fitting winter specification tyres, the low profile is too severe as I found last year
    What you really need are narrower wheels, which can then cut through the snow, not sit on top of it
    The height of the snow was just too much and the front of the car could not clear the snow
    I doubt there will be the same issue this year, but if there is I do the same again and simply cancel all work until the roads are safe again
    spoons
    Guest
    ...the low profile is too severe as I found last year
    I'm not taking the VXR out in the snow this year, but I have got Winter Tyres for the Fiat 500.
    I normally run 16" low profile tyres, but have bought a set of 14" steel wheels with Goodyear Ultragrip 7+ tyres.
    I'll put them on as soon as the weather temperatures drop below 5 degrees regularly. So anticipating November / December time through to March
    Fife
    Sorry if this is total dumbness but the tyre size I have on the now are 215/50/17. I was wondering if I could put different tyre size on as long as I kept the same diameter for example 225/45/17???
    winter tyres at 215/50/17 seam quite hard to come by and a good bit more expensive than 225/45/17
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    I am driving on 235-40/18 Michelin Pilot Alpin PA3.
    I disagree in the fact the narrower tyres should be bette in the winter.. Sure if you have a little car like the Fiat 500 or similar...
    With narrower tires on a heavy car you slice through the snow to have traction on the icy tarmark. Result NO friction at all. The goal for heavy´er cars is to stay in the snow because friction is higher in snow than on pure ice.
    Last year I drove my 04 V6CDTi on 225-50/17 Conti´s TS830 P on spec. "Elegance" alloy wheels and not once did the car do something it shouldn´t do. It drove like on rails. I drive 50 miles back and forth to work.
    The pattern is also not the same i small sizes as in the bigger sizes. Because manufactures have calculated what pattern to use with bigger and wider tires.
    Because I am from Denmark we have harsch winters and a lot of rain to.
    I would not for one second use summer tires in the winter. They can´t cope with the snow at packs the pattern on the summertire, so you might as well drive on fully worn tires instead. Same effect.
    Here in Denmark the cars are more expensive and insurence rates therefore are higher. Tires is expensive also but is adds up when you see it in the long run.
    I would say the 85% of all cars in Denmark use wintertires.. the last 15% dosen´t need to take the car if there is snow.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    I used winter tyres on my 2.8 last year and was shocked at how good they were. I would honestly recomend them to everyone
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    I Agree with the last 2 comments.
    I fitted 215/55/16 Continental TS830 to my 2003 2.0Dti this time last year and just left them on.
    No problems at all, great tyre in the snow, but they were £460 fitted for all four at Kwik-Fit. And no they didnt try to up-sell anything else to me, nor tell me my car was falling apart.
    The front two will be replaced this time next year, after about 20,000 miles.
    It did cost £60 per wheel more but in the overall cost of the car it's not a lot. Especially if you love your family and dont love sliding about in the snow.
    Link to Kwik-Fit Winter Tyre Q&A.
    http://www.kwik-fit.com/winter-tyres-faq.asp
    Winter tyre Test results
    http://www.tyrereviews.co.uk/Article...-Tyre-Test.htm
    But bear in mind that not all tyres in all sizes are available in this country, which is why I choose Continental's.
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    i had winter tyres fitted to my megane coupe last year but they can be used all year round apparently.
    i did notice a difference in the snow and ice but it was due new tyres anyway.
    i would defo consider it again tho, its law in a lot of european countries.
  1. Big winter tyres!
    By sriandy in forum General Motoring Chat
    Last Post: 26th October 2012, 19:00
  2. Winter tyres or wet weather tyres?
  3. i wish i got winter tyres
    By 6009tristanb in forum General Motoring Chat
    Last Post: 21st December 2011, 02:32
  4. Winter tyres - What do you do?
    By lewcdti in forum Handling & Braking
    Last Post: 16th September 2011, 23:40
  5. Winter tyres
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2010, 20:50
