Thread: 2.8 turbo oil leak?
    Sep 2010
    Devon
    Default 2.8 turbo oil leak?
    Just bought a 2006 2.8 turbo Elite Vectra estate,
    to replace a 2008 2.8 turbo Elite Vectra hatch.
    Just put it on the ramp to change the engine oil and noticed oil leak on the nearside, very messy around driveshaft, steering rack, but also messy up as far as the bottom of the battery tray,
    Turbo looks clean,
    looks like engine oil
    not noticed any drips on tarmac.
    In one place the bottom of the shock it looks almost like "liquid grease"
    All fluid levels seem OK,
    Gearbox level check more tricky.
    Not done enough miles to see if engine oil level drops much.
    Any Ideas would be appreciated
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Gearbox drive shaft seal and flicked up the oil? Or from the breather
    Regular Member SRIDAN's Avatar
    Out in the Estate
    8 Post(s)
    Vehicle : Sri Estate Navi xp2
    Trim : Leather
    Engine : Z19dth + a Teapot
    Mileage : 94000
    Hi
    Have you looked at the cam cover gasket?
    Sep 2010
    Devon
    Sorted!!
    Was grease from drive shaft boot, not secured properly.
  1. CDTi (120) Turbo oil leak
    By Casey in forum Engine & Drivetrain
    Last Post: 10th April 2012, 20:40
  2. Small Oil LEak @ Turbo. 2.0L DTI
    By mick 1986 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 21:58
  3. cdti turbo oil leak
    By sla002 in forum Engine & Drivetrain
    Last Post: 26th July 2010, 16:04
  4. Possible oil leak from turbo
    By Gazza36 in forum Engine & Drivetrain
    Last Post: 19th February 2010, 19:56
  5. CDTi turbo oil leak
    By IamtheStig in forum Engine & Drivetrain
    Last Post: 16th October 2008, 20:32
