Thread: Hi from Serbia
    Regular Member strela's Avatar
    Oct 2011
    Serbia
    Default Hi from Serbia
    I'am on a step before buying Vectra C - 2006. Engine is petrol 1.8 140PS. Is there any faults I should take care of before final decision?
    Thanks.
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    open the wallet lol... Check the cat, rear shocks, bushes, front strut mounts. The 1.8 Engine is prob the most reliable, so just look after it and should be fine.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    the only problem i found with 1.8 is the engine mounted ecu, have a tendancy to fail due to heat and vibration
    Oct 2011
    Serbia
    Thanks for comments.
    @MURDO
    Putting KYB in it - will this make problem dissapear?
    @Neill
    Did you mount ECU on some "absorbers" - how did you solve vibration problem?
    Regarding temperature - is it its own temperature or environment/motor temperature that causes problem? Do you have some pic of ECU in motor compartment, so I could know where to look for it?
    I'm also considering to put BRC sequent gas equipment in it. Have anyone done it on this motor?
    Thanks in advance.
    Best regards.
    Welcome to Vec-C Strela
    You'll be better off asking your questions in the other parts of the forum where there is more visiting traffic.
    As the title of this sub forum suggests, it's a place to introduce yourself.
    The sticky post "Please Read before posting a NEW THREAD !!" also mentions
    Introducing yourself = Come in, say hello and introduce yourself.
    Please don't post your questions in here !! Say hello then goto relevant section regarding problem !!!
    Oct 2011
    Serbia
    Thanks Dave,
    you're right. I'll post it there.
    Best regards.
  1. Olympics 2008 - Ladies water polo: Serbia vs. Albania
    By Taffyopel in forum Comedy & Humour
    Last Post: 19th September 2008, 10:09
  2. Greetings from Serbia
    By vectra c caravan in forum Introduce yourself.
    Last Post: 16th November 2007, 16:58
