Thread: Glowplug switch
    cambridgeshire
    Default Glowplug switch
    Hi guys how would you fit a manual glow plug switch to a vectra 1.9 cdti 8v
    kind regards
    matt
    West
    you shouldn't need to... there must be a fault on the pre heat system if you thinking of going down that route
    north east
    It works off the coolant temp sensor.
    Aug 2010
    Leeds
    Quote Originally Posted by matt_harw View Post
    kind regards
    matt
    Why do you want to?
    But should you do id go with a resistor inline with a push button to feed the plugs you will have to find out the voltage as some plugs are 11.5 vdc so not to burn them out.
    Is the relays or timer working on yours?
    cambridgeshire
    if you look at my other thead I've had major issues with starting so need this as a backup
  1. no glowplug light, why???
    By frasedeb in forum Engine & Drivetrain
    Last Post: 22nd January 2013, 23:05
  2. glowplug light
    By clyde in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2011, 00:39
  3. DTI Glowplug Change
    By si_hoss in forum Engine & Drivetrain
    Last Post: 10th June 2010, 12:49
  4. glowplug light
    Last Post: 13th October 2009, 13:54
  5. glowplug light
    By bob4 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th October 2009, 20:52
