Thread: exhaust manifold 19cdti
    Regular Member mark the hat's Avatar
    Jan 2008
    manchester
    Default exhaust manifold 19cdti
    anyone had a blowing manifold on their 19cdti,
    as mine has just started blowing top right as you look at the engine
    how much do garages charge for a new gasket to be fitted ????
    cheers mark
    Jan 2008
    manchester
    just got home all be it very loudly
    found the problem but dont know what the part is called anyone ????? help????
    it is a metal pipe that comes off the front of the exhaust manifold (heat cover)it is bolted on by 2 bolts and comes away from the manifold with a consatinea bit then straight bit then consatina bit again then go's around the right hand side of the engine(as you look at the engine) under a couple of rubber hose's thats all i can see
    so anyone know what this pipe is for and what its called so i can get 1 asap
    cheers mark
    Jan 2008
    manchester
    found out what the pipe is.......egr pipe runs from the back of the egr to the front into the front of the manifold down the side of the engine......136.64 from the steelers...........30/40 from a scrappers sweet now to fit it.......
    mark
    East Ayrshire
    Trim : SRI XP1
    good stuff. glad you found out what it was
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Don't forget to order new gaskets from Vx...there's one for definate on the end that attaches to the turbo and there maybe another at the other end.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    don't forget to replace the gaskets
    Jan 2008
    manchester
    will do,i go past oldham steelers to pick the pipe up so i'll call in on my way cheers
    mark
  1. Z22SE Manifold & Exhaust
    By Lean6 in forum Petrol Engine related
    Last Post: 9th August 2012, 23:03
  2. found this ,,,intresting 19cdti inlet manifold
    By embo in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2010, 08:45
  3. Exhaust Manifold for 1.8 VVT
    By Gray16v in forum Petrol Engine related
    Last Post: 23rd December 2009, 23:34
  4. exhaust manifold
    By KeefyB in forum Petrol Engine related
    Last Post: 19th September 2009, 22:01
  5. Inlet & Exhaust manifold
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2006, 15:15
