Thread: Hunting 3.0 V6 cdti
    Aug 2009
    Ascot
    Default Hunting 3.0 V6 cdti
    I know I have posted up a few things recently, but need some pointers. What could cause hunting at idle? Whatever is my prob at moment is linked to iratic idle revs
    Nick
    There are many reasons why this could be happening
    I would start with these two :
    A
    Disconnect the throttle and compare
    B
    Check the exhaust condition (possible blow back)
    It is also possible the injectors have become contaminated, especially if you notice the revs on power are erratic as well
    Aug 2009
    Ascot
    But it's intermitant , it always follows me flooring it, car going into limp mode and then poor idle. As soon as I turn ignition off then on again it's fine, and no codes
    Nick
    Quote Originally Posted by s2yob View Post
    That is the engine going into safe mode
    Do not turn the engine off and have the fault code read
    Mine does it once a month and dealership scratched head, "er, the warning lights were on when we started but there is no fault code stored, when we restarted the engine all was fine"
    Usually starts with an increasing amount of black smoke on flooring it with a cold engine, then as the days pass all the time, then finally fault code and safe mode
    Switch the engine off, wait 5 minutes, then all is normal
    It has only been doing this since the SCV was replaced and I suspect it is a program to discharge dirt from the fuel pump
    north east
    sounds like crank shaft speed sensor to me.
    does it happen after holding a cruising speed of 80 mph ? anr / or only once the engine is upto operating temp.
    Quote Originally Posted by roswell View Post
    Very unlikely as when this fails it normally remains failed (similar to front brake pad sensor)
    More likely would be the camshaft sensor as this can throw up safe mode a few times before finally failing, also often makes the EMS light flash or flicker as it nears failure
    Aug 2009
    Ascot
    Will keep that one in mind
    Although knowing this engine that part will be +£500
    probably nick , easy to change though a 30 second job
    The camshaft and crankshaft sensors are all very similar on the VX engines
    I've not known one to be over £150 yet, including fitting
    Obviously the camshaft sensor is easiest, so I might get a quote next time
  1. Job hunting
    By Critch in forum General Chat
    Last Post: 10th March 2012, 13:59
  2. Fw Help ban fox hunting.
    By bobssignum in forum Comedy & Humour
    Last Post: 21st November 2010, 18:26
  3. Hunting idle on 2.0t
    By Morephun in forum Engine & Drivetrain
    Last Post: 17th June 2010, 12:35
  4. Fox Hunting
    By fingers66 in forum Comedy & Humour
    Last Post: 14th April 2009, 20:56
  5. Fox Hunting
    By Dodger in forum Comedy & Humour
    Last Post: 16th December 2007, 00:47
