Thread: CDC 40 - Tech 2
    Regular Member bigstorer's Avatar
    Swansea
    Default CDC 40 - Tech 2
    Hi,
    Recently bought a CDC40 opera and now want to have little play :P
    I have been to the stealers and they dont have a clue (as normal)
    I want to know:
    1. what can be tech2 enabled on the unit?
    2. what additional inputs are available? (I know about the DAB and have seen something about bluetooth)
    3. If bluetooth is available then how do you go about it?
    Think thats it for now
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    for the bluetooth you need to get a UHP100 or UPH100 not sure which it's called, but it's a xtra module that plugs into the your CDC40 and should come with a microphone. Someone else here might have more info on this.
    For the DAB you'll need to get this http://www.ebay.co.uk/itm/VAUXHALL-D...item3f0e7ca15a
    Swansea
    ok thanks.
    I have googled both those model numbers and pull up anything relevant.
    Are there any aftermarket DAB aerials and connections? this one is a little out of my price range at the moment
    Swansea
    If I was to just go into vauxhall of things I wanted them to Tech2 Enable on the unit what could I ask for?
    Cos then I could get it all done and add the various components later.
    Also is there an easy way to update the software on it?
  1. Tech 2 help
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:35
  2. tech 32 ?
    By les287 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:04
  3. tech 2
    By jamesworts in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 08:17
  4. Tech 2
    By WHOOSH05 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 16:54
  5. Tech 2
    By cooky516 in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2008, 11:36
tech 2 vauxhall cdc40
