Thread: 1.9 cdti sri Fuel pipe size?
    Oct 2011
    wales
    Default 1.9 cdti sri Fuel pipe size?
    Hi there, can anybody tell me what size the fuel pipe is for me to order a one way fuel valve, i have seen 6,8,10mm!!!!! thank you!!
    Which fuel pipe, and what's the valve for...?
    Oct 2011
    wales
    having problems starting when car has been standing more than a few hours, need to install a one way valve onto the fuel pipe coming from the tank, thanx
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    is it definetly a 1.9 you have as the 2.0 and 2.2 are more prone to this problem, i'd be looking into the problem more if its on the 1.9 engine
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Doesn't the 1.9 have the pump in the tank as well as the HP pump? If so then that may have failed.
    The tank has it's own pump which you can hear running when you turn the ignition on. It allows you to easily bleed the system so unless that's failed a 1-way valve won't make a jot of difference...
  1. fuel pipe split.....cdti
    By mark the hat in forum Engine & Drivetrain
    Last Post: 13th November 2016, 12:06
  2. cdti fuel feed pipe
    By ronnie63 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2012, 14:50
  3. FUEL TANK on CDTI Estate 150 - what size it ????!!
    By textilewales in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2011, 07:23
  4. help cdti fuel pipe popping out .......
    By wirrallad in forum Engine & Drivetrain
    Last Post: 20th March 2011, 00:02
vectra c 1.9 cdti 07 engine fuel pipe split
