Results 1 to 2 of 2
Thread: FITTED XTRONS TD717 with pic
    S.Shields (Newcastle)
    Default FITTED XTRONS TD717 with pic
    Well, after a right chew on, its in at last!!
    I removed the standard unit, and then took the standard cage out, as it isnt deep enough for the xtrons unit. Fitted the unit and then decided it stucjk out to much.
    So took the unit back out and took a hacksaw to the plastics at the back of the radio unit which is part of the dash and cut away at the back to enable the unit to side further back. Looks much better!!
    Uploaded with ImageShack.us
    Regular Member Bethan39's Avatar
    South Wales
    I've got the same in mine did the same as you and cut off the bit at the back. I think I need to put mine back a bit more. Couple of quick questions if you don't mind? I take it you tilt the face to remove it because of the daft place to unclip the face off? Do you find the screen suffers from screen glare I can hardly read mine due to glare! I've tried to adjust the brightness but it makes no difference. I've a few more but I'll leave you alone for now lol cheers.
  1. xtrons TD601
    By Rob12 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2011, 22:36
  2. For Sale: xtrons 717 for sale
    By coooky in forum Parts for sale
    Last Post: 30th September 2011, 21:07
  3. Xtrons Td717
    By Bethan39 in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2011, 16:41
  4. confused about xtrons
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 10th August 2011, 18:39
  5. Tip for Xtrons installations
    By Vectra Forever in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 10:08
xtrons td717
