Results 1 to 10 of 19
Thread: Fault codes - what are they?
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default Fault codes - what are they?
    Hey guys, i just read the codes on my vectra c 2003 and i have absolutyl no idea what any of them mean really so in order to fix the huge list i was wondering if people could shed some light on any of these that they know?
    I know that my inet manifold has an air leak, my CC has no clutch switch (because the wires have been linked up to bypass this) and my aircon doesnt work - but other than this i had no idea i had any faults!
    B3115 - Remote-Key 2 Not Synchronized
    (00) - Not present
    B3700 - Wiper Interval Circuit Open or High Voltage
    (04) - Not present
    B3840 - Wrong Stalk Switch Configuration
    (00) - Present
    B3840 - <Unknown DTC>
    (0F) - Present
    B3794 - Switch Cruise Control Circuit Open or High Voltage
    (04) - Present
    B2657 - Illumination Circuit Malfunction
    (00) - Not present
    B3926 - Wrong Environment Identifier Received DDM (Driver Door Module)
    (00) - Not present
    U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
    (00) - Not present
    U2108 - CAN-Bus No Communication with ABS (Anti-Lock Brake System)
    (00) - Not present
    U2111 - CAN-Bus No Communication With EHPS (Electro-Hydaulic-Power-Steering)
    (00) - Not present
    U2116 - CAN-Bus No Communication with IPC (Instrument)
    (00) - Not present
    U2141 - CAN-Bus No Communication with REC (Rear Electrical Centre)
    (00) - Not present
    U2113 - CAN-Bus No Communication with SDM (Sensing & Diagnostic Module, Airbag)
    (00) - Not present
    P0704 - Incorrect Clutch Switch Signal
    (0F) - Not present
    P0400 - Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    (F8) - Not present
    P0400 - Exhaust Gas Recirculation Circuit Open
    (04) - Not present
    P0234 - Boost Pressure Control Circuit Negative Deviation
    (5A) - Not present
    U2103 - No Communication with CAN-Bus (High Speed)
    (00) - Present
    C1523 - System Voltage Low Voltage
    (03) - Not present
    C1526 - Motor Malfunction
    (00) - Not present
    C1531 - Steering Angle Sensor System Voltage Circuit Low Voltage
    (03) - Not present
    C1550 - Replace Electronic Control Unit (ECU)
    (37) - Not present
    U2105 - CAN-Bus no Communication with ECM (Engine Control Module)
    (00) - Not present
    U2105 - CAN-Bus ECM Message Range/Performance
    (71) - Not present
    U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
    (00) - Not present
    U2107 - Invalid Data from BCM (Body Control Module)
    (71) - Present
    B2996 - Rear Left Door Switch Circuit Open or High Voltage
    (05) - Present
    B1375 - Switched System Voltage (Ignition ON) Circuit Malfunction
    (00) - Not present
    B3974 - Driver Door Select Switch Window Lifter Circuit Open or High Voltage
    (05) - Present
    U1420 - Radio Bus Communication SDA open
    (04) - Present
    U1421 - Radio Bus Communication SCL open
    (04) - Present
    U1422 - Radio Bus Communication MRQ open
    (04) - Present
    U1423 - Radio Bus Timeout Error
    (72) - Present
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Clear the faults and see what your left with. Theirs far too many to all be ther
    Feb 2011
    Selby
    Far too many there to make any sense of it. Also a lot of them relate to the ignition being turned on with some major connector unplugged (hence all the 'communication failure' ones. I suspect most of the faults that these codes relate to are now no longer present.
    Clear the codes, then go for a test drive and then read the codes again.
    Sep 2011
    Sipson
    My auto sparky got a massive list like that too, though I meant to ask him how, cos I can't see them, I can only see ECU alerts.
    Are you getting the car and spanner light on your dash? I have it coming up too and from what we can tell it is not a malfunction per se, but a problem with the electronics. However, everything works on my car, cruise, A/C, etc etc. The only exception being a warning for front fog light and safeguard. My auto sparky had the CIM and dash out and reckoned the CIM had been bypassed with something soldered in the way, which is how he reckons the car and spanner is being thrown up.
    But as everything works, or appears to, I can't see that being right, so I wonder if it is a result of being half can bus?
    Let me know how you get on and I'll update you if I find anything too.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    do you have the original head unit in the car ??
    Sep 2011
    Sipson
    I do, though am looking to replace it, as easy job cos only half canbus. Or was that directed at OP? (most likely)
    Full Member
    Bristol
    Someone is using an old copy of op-com to get a lit like that. Op-com old version picks up ever blip going as you can see. So get the code read by snap-on or tech 2 .
    Sep 2011
    Sipson
    The first time he read it the errors didn't come up, and my code reader only finds the ECU ones, i.e. Pcodes, should a regular code reader also get the B,C and U codes as well? But he read it yesterday when I wasn't there so I don't know what he did it with, I know he has opcom, bosch, autodiagnosis, but perhaps he used his old copy of opcom and got all those errors.
    Full Member
    Bristol
    Yes the old op-com picks up ever voltage drop as tech 2 and snap-on don't op-com the old verion geve me alist as long as you arm. But the new op-com does not it works perfect.
    Feb 2011
    Selby
    A generic code reader will only get the P ones (from the engine control unit), as the others are GM specific, so would require a code reader that knows how to interrogate the other control units. For example, Op-com and Tech2.
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
b3926 opel
u2107-71
Vauxhall U2113-C
u2107 fault code opel corsa
0pel u2107-71
U207-71 INVALID DATA FROM BCM VECTRA C
b2657 vectra fallo
Vauxhall DTC U2107-71
u2107 code opel vectra
b3926 opel vectra c
Opel U2107-C
b2657 opel
b2657 vectra
b2657 - illumination circuit malfunction
B2657 vectra c
opel vectra c B2657
opel corsa u2107-0
opel u2107-00 code
Vauxhall U2107-71
b2657
vectra c u2107-71
vauxhall b1375-00n
what does u2107-71 code mean on a vectra
b3926 error vectra c
https:www.vectra-c.comforumshowthread.php148721-Fault-codes-what-are-they
