Thread: Mounting a satnav on the dash...
    Chelmsford
    Default Mounting a satnav on the dash...
    Hi guys,
    recently bought myself a Tomtom Via Live (which is awesome by the way) and picked up one of the black plastic discs which you put on the dashboard to attach the satnav sucker mount to.
    BUT...
    I've not attached the disc yet, as I'm worried that I'll want to remove it at some point and it will either A) not budge or B) leave a horrible sticky mark on my dashboard!
    Anyone care to put my mind at ease? At the moment I'm sticking the Tomtom in the middle of the windscreen, but it's very hard to reach!
    Jun 2007
    Cheshire
    Try something like this.
    Got an earlier version and it works well. Bit expensive but maybe cheaper versions around
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    what about something that sticks it to the windscreen instead?
    i have one for my phone off ebay as i have satnav on my phone
    uk
    I connected my disc to a spare switch at the side of the radio. I drilled and bolted the 2 together, using a disapearing head bolt (grind it down util it is flush) and put a very thin rubber washer to seal it (make sure everthing is smooth). If it as an arial wire it will locate inside the pull away moulding, running it across the passenger side. The spare wire to lighter will tuck away in the square hole under the radio.
    I hate to have wires danggling and this prevents the senareo. And if needs be, I can pick up a new blank for the switch for a few quid.
    The only downside is at first I used to keep catching it as I moved my hand from the gears to the wheel, but I soon got used to it.
    Regular Member madman's Avatar
    nottm
    Try a navmat. had mine 2 years and it doesn't budge unless really pushing it through corners.
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    Ive made a dashmount that fits in the heater vent.
    Holds it just fine
    Chelmsford
    Thanks for the advice guys,
    Kel, could you post up a photo of yours? sounds good...
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    i'm with digital mines in the heater vent, spot on
  1. Permanently mounting an external satnav
    By Yugguy in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2012, 11:38
  2. FOR SALE: Brodit phone/satnav dash mount
    By merikiito in forum Parts for sale
    Last Post: 3rd February 2011, 19:15
  3. PDA Mounting
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2007, 17:12
  4. mounting sat nav/phone to chrome strip on the dash
    By hsmeets in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2007, 22:42
